04-12-2016, 08:16 PM | #1 |
Drives: 96 t/a / Hyper Blue 1SS MRC M6 Join Date: Feb 2016
How much boost...
After searching couldn't seem to find the answer to this question. I was just curious to know how much boost is the LT1 able to handle reliably (before adding methanol, fuel etc..) Also how long? Any one seen any threads about c7's being boosted long term? any issues? Just curious.
04-13-2016, 07:44 AM | #2 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
You'll hit a bottleneck with fuel delivery before you approach the limits of the LT1.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
04-13-2016, 07:15 PM | #3 | |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
After all that, Florida Speed and power made 1291 whp on 26 pounds of boost using a Procharger F1X. Motor was completely built. As pointed out by Lesbaer, they had a problem getting more fuel into the engine. http://www.corvetteforum.com/forums/...injection.html
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
04-14-2016, 12:46 PM | #4 | |
04-14-2016, 12:47 PM | #5 |
I think he just meant that you will run into issues with fuel where you would have to do something like meth injection, before the bottom end went out.
04-14-2016, 01:38 PM | #6 |
FMPG
Yup...that's all I meant. Thanks
04-14-2016, 01:47 PM | #7 |
Drives: 1970 Vette,16 1SS, 07 Ford Taurus Join Date: Aug 2015
If you have a no forced induction car and then add a blower or turbo and are running above the stock boost levels I would add meth injection every time especially with the direct injection the Camaros have. Its a no brainer and not that expensive. When and if I add a supercharger or twin turbo setup I will definitely be adding methanol injection. I can't think of a good reason not to add it actually.
04-14-2016, 04:26 PM | #8 | ||
Speed Freak
I will say that the tuners seem to be working a lot harder to make big power with these new LT motors. With the LS motors every shop out there was kicking out 750+ whp builds left and right over the last few years. The 750+ whp build is currently pretty rare on a LT motor. I think 700 to 800 whp should be pretty safe once everyone figures out how to fine tune the LT. Quote:
But having said all of this I'm not totally against methanol. There are clearly a lot of advantages to running it. I have been told that my '16 SS will have a meth injection system the next time I see it. I had a meth system on my ZL1 for a while....
04-14-2016, 06:15 PM | #9 | |
where are you finding these cars?
04-15-2016, 11:00 AM | #10 | |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
If this forum had a "like" button you would have got one there.
04-15-2016, 12:13 PM | #11 | |
Speed Freak
Enter the '16 Camaro with the LT1. We are just now seeing the first turbo kits tested by Redline (thread on this board) and AGP turbo is making a turbo kit for the '16 Camaro but the details are not available yet. Many companies have come out with PD superchargers but the power numbers so far have been around 500-600 whp. I personally think the PD supercharger is the best option for a street driven car. They are the most reliable and have the most power/torque at low engine rpms where modern cars are cruising to conserve fuel.... and the base ECS kit is right around 600 whp in the stingray. Yes there are bigger centri builds out there like I noted in my first post but they are not as common. Here is a link for base kit: http://www.corvetteforum.com/forums/...k-vehicle.html
04-15-2016, 05:00 PM | #12 |
Drives: Chevys at the limit Join Date: Nov 2010
Centri blowers do NOT make the same low end torque a PD Blower makes. Not even close. I'm not going to get into which is better but I felt inclined to correct in this situation.
All the best, Jared Royce 801.545.4215 |
04-15-2016, 05:46 PM | #13 | |
We offer ECS and ProCharger Kits |
04-16-2016, 07:20 AM | #14 |
Drives: '14 Z51 C7 SC'd, '14 S4, '15 SQ5 Join Date: Jul 2015
I have an ECS C7 with Meth.
First off, no one really knows how they compare on a dyno at low RPM because most dyno's start at around 3000rpm. I would not put a PD blower on a Corvette or Camaro unless I only wanted around 500-550 hp and similar torque to the wheels. Low end torque sounds great and is great with traction, without it the car is a pain to drive. WOT there may not be much performance difference but part throttle driving around the PD will probably be more enjoyable because even at light throttle it does make way more torque. it is also the reason the gas mile sucks. Our other 2 cars have PD style blowers and for small 3l V6's, both around 420hp, the mileage is abysmal. I would have went with a PD blower but not with the tiny tires on the C7. I think the Camaro will take a much larger tire without forged wheels and a bunch of fitment drama like there is on C7 but even then unless you have a drag radial your driving around on the traction will not be there. A Centri blower you get a better mix. At WOT performance is similar, you can make way more power without fighting heat, and the gas mile hit is not bad. I don't take the gas mileage thing as a decision maker, I don't drive the car to make X MPG, I drive the car to enjoy it and is a poor argument overall in comparing the two. Now add in the price difference and there is a huge difference. A PD blower on a C7 is going to hit you for around 10K all said and done. My ECS kit was $4,800, install with tune was $1,300, and a meth kit later on was $1,200 installed and retuned. $7,300 installed and tuned for 645RWHP and if I remember right 585rwtq. No where near as much torque but much better overall drivability from a traction standpoint. The safe limit for a stock LT1 is a bit more than I am pushing but I wanted it safe so I do not have headers and I'm right at the traction limit most of the time as it is. |
