03-02-2016, 06:23 PM | #295 | |
Owning SSes for 50 Years
I am quite certain the "base" engine in the new Camaro is only the beginning of a long line of great factory high performance cars that more often than not outperform their Ford counterparts. I give credit to Ford for going way out on the limb to build the Voodoo, but it has to be disheartening to spend all that money on that engine for the relatively poor performance output. Of course that's my opinion. I guess HP is one measure of the value of a car, but I honestly see that Chevrolet has done wonderfully well in every automotive arena using the engines they have built and raced. Seems to me, they have developed an excellent all-around sporty car that doesn't need the highest HP to win. I'm sure you would be willing to give a tip of the hat to that fact...lol. All the Ford guys point to the fact that the small displacement Coyote and Voodoo put out a lot of HP for their size and sometimes use that as an excuse for it's poor performance...ok, but it usually takes a back seat to Chevy's bigger engines. Ford could have built any size engine they wanted.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
03-02-2016, 06:47 PM | #296 | |
i think if we get a chart with the mph next to the rpm of the gt350 in each gear it would be useful this is the best i can do ATM GT350 First: 3.253:1, Second: 2:233:1, Third: 1.611:1, Fourth: 1.24:3, Fifth 1:1, Sixth: .629:1, and Reverse: 2.955:1. lets just look at the first column Last edited by 6spdhyperblue; 03-02-2016 at 07:31 PM. Reason: ah crap i was late to the party |
03-02-2016, 06:48 PM | #297 | |
address and tell me how many Coyote engines hold any of the speed records. Then count the number of 2005 and up Chevys with LS engines you find there. If you counted them overall Chevy lists tons more records than Fords. Well...8 Lemans wins is a pretty good indication and that's well proven. Not counting the Prototype wins Check this site out: https://nurburgringlaptimes.com/lap-times-top-100/ and you'll find 6 LS engines in the top 100 fastest laps at Nurburgring and there were 2 Fords. We could talk about the LS engine's success as a GT winner and find no Fords winning a race much less a podium finish. Are you kidding, I would throw up if that ever happened...lol.
03-02-2016, 07:37 PM | #298 | |
Moderator.ca
I don't have the time or inclination right now to go through everything in a detailed comparison between the drivetrain setup between the two cars, but here are the basics of how it all works together: If you have a 'fast' engine, the drivetrain is generally going to be setup more aggressively, making for a greater gear reduction (and consequently converting some of the extra engine speed into torque at the wheel). This means that for a given wheel speed, the engine will be turning faster than it would be on a normal car. Alternatively, if you have a 'slow' engine the opposite will normally hold true. It will have less gear reduction, meaning that for a given wheel speed the engine will tend to be turning slower than an average engine. Most cars are geared in such a way to achieve similar (wheel) speeds in the same gear -despite the engine turning at different RPMs to accomplish this. In the end, ultimate engine speed is no more or less important to shift points than any other part of the drivetrain. You can have a torquey, slow engine with lazy gearing such that it can happily cover 50 mph to 130 in a single gear and barely needs to be shifted around a track. You can also have an engine that revs to the moon but is geared so aggressively that you'd have to shift 3 times to get from 70 to 110. Neither one of those combinations would be particularly great around a track, I'm just using it to illustrate the point that engine speed isn't the be-all and end-all of when you need to shift (which seems to be the general point of that blurb of yours that I quoted).
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
03-02-2016, 07:52 PM | #299 | |
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
03-02-2016, 08:32 PM | #300 |
Drives: 2016 F150 Join Date: May 2014
Some things are simply common sense.. Or should be. You don't have to know the inner workings of vehicle parts.
03-02-2016, 08:32 PM | #301 |
Drives: 2012 Ford Focus Join Date: Jan 2014
I'm pretty sure speed knows what you all are talking about. The point he's getting across is they have done just that for the voodoo. They've taken advantage of its RPM band and adjusted gearing to where you could practically stay in 4th around the majority of the track.
03-02-2016, 08:35 PM | #302 | |
03-02-2016, 08:37 PM | #303 | |
He said the GT350 will keep pulling way after the Camaro shifts because the voodoo revs higher.. There is no way to twist what he said to make it seem like he didn't say something idiotic. |
03-02-2016, 08:39 PM | #304 |
03-02-2016, 09:30 PM | #305 |
Drives: Several in a big garage Join Date: Jan 2014
The fact is, on a road course, you are going to be shifting the GT350 much less often than the SS Camaro. Those shifts will cost you time, no way around it. In addition, the GT350 only has one overdriven gear, the Camaro has two. This is one factor that contributes to the better MPG for the SS versus the GT350.
03-02-2016, 09:36 PM | #306 | |
03-02-2016, 09:52 PM | #307 |
Drives: Want a gen 6 Join Date: Jan 2013
Does anyone know what mph the gt350 3rd to 4th shift is at? That's the key here, because you may be as likely to have to downshift at gt350 into 2nd as you are to have to upshift an SS into 4th depending on the track.
03-02-2016, 09:54 PM | #308 | |
Sent from my SAMSUNG-SM-G920A using Tapatalk
Thread Tools | |
