#323 |
10,000 miles later and a bunch of track days and I have not had any issues since using the GM locknut with attached rotating washer and torquing using the crowsfoot method. I wound up torquing the hex driver since the crowsfoot can't move much. Also had a helper since there were 2 wrenches involved. After torquing add some witness marks so you can inspect for any movement. Nut is GM # 11548382
Last edited by carguy55; 12-07-2020 at 04:42 PM. Reason: Addded GM p/n for the new nut 11548382 |
#324 | |
![]() Drives: SS1LE Join Date: Nov 2017
Fix the Clunking Noise (Video Tutorial)
Hope this helps! Let me know what you guys think.
Disclaimer: I am not a automotive technician, just a guy trying to fix his car |
#325 |
That's a pretty good video. Makes it a lot easier if you happen to have it on a lift. You don't need the nord locks if you have the new GM lock nuts
#326 |
![]() Drives: Rally Green 2020 ZL1 1LE A10 Join Date: Jul 2018
Thinking I have a similar issue. Taking it in Wednesday
#327 |
![]() Drives: 2018 Camaro 2SS, redline edition Join Date: Jun 2013
I cannot believe this is still happening on the newer models:((
On my 2018 2SS, both the left and right front bolts came loose. |
#328 |
![]() Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
Hey guys, ran over this whole thread and must be blind. What's the PN for the Nord-Lock washers I need to buy?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
#329 |
#330 |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
Hey all. Have clunking on the track when changing direction through turns. Before, I have found the front strut nuts were loose enough that the camber shifted on turns. The alignment guys didn't (or couldn't due to clearance) get them tight enough. I check them for torque after each track event. Not great at 150 mph. Need blue locktite on those. This time will check the sway bar end links.
#331 | |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
#332 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i replaced my old powergrid ones with the spl parts ones if anybody needs a set of used adjustable endlinks lmk!
#333 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
So I understand that the suspension has to be loaded in order to verify this condition, as opposed to jacked up and the wheel hanging? I don't get much noise, minor click that is intermittent but car has a front end push on just about any kind of other than mild cornering that I've been chalking up to this tire and/or the alignment.
#334 | |
Matt Miller
2020 SS 1LE |
#335 |
That is correct and torque correctly. Also add witness marks after torqueing so you can inspect them quickly for any movement.
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87 |
#336 |
![]() Drives: Chevy Camaro Join Date: May 2020
Just had the same issue. 2018 SS
