Old 07-29-2016, 09:48 AM   #29
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Originally Posted by JANNETTYRACING View Post
I am curious where your blow off valve is in relation to the MAF.
A MAF should always be After any blow off valves.
Or when it is open the maf is seeing air flow that is not entering the engine and fueling will follow making a very rich condition.
Ted.
Hmmm, I don't know where the blow off is but I'm pretty sure it is after the intercooler. When I lift after a full throttle burst I can sometimes see a little white cloud come out of the hood vents that I assumed was the methanol coming out the blow off and the hood vent. I do have more black soot on the exhaust tips than I considered normal but attributed that to the removal of the cats.
I always say I'm the driver and not the mechanic but try to stay pretty well informed on what is going on. I'm kind of thinking that these direct injection motors would have to respond more to throttle position than air flow because they are more well... direct but I really don't know for sure.
Is there a way to work around that in the tune?
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 07-29-2016, 10:05 AM   #30
JANNETTYRACING
JANNETTYRACING's Avatar
The only work around is Speed density Only tuning.
The bypass valve should be before the intercooler, then the MAF should be after the intercooler and the Meth injection should be after the MAF.
The further you move the MAF from the engine the more lag in signal.
Remember Air flows like a Slinky, you move the Throttle then the MAF sees the change in air flow, then the computer changes the injector on time and spark values.
The further it is the more the time delta.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 07-31-2016, 07:11 PM   #31
jessrayo
Speed Freak
jessrayo's Avatar
Ted.
Well I found out the blow-off on Borg Warner EFR's is right on the turbo so you don't get much closer than that. It is probably the most responsive turbo system I have ever driven.
Old 07-31-2016, 07:53 PM   #32
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
The videos aren't loading for me.
cleoent is offline   Reply With Quote
Old 08-01-2016, 09:05 AM   #33
jessrayo
Speed Freak
jessrayo's Avatar
Its just photos, no video.
Old 08-01-2016, 09:40 AM   #34
JANNETTYRACING
Good Stuff.
I would still like to see the MAF after the intercooler and closer to the TB.
This way the MAf is in the right size pipe, and sees actual charge temps entering the TB.
Ted.
Old 08-01-2016, 12:35 PM   #35
jessrayo
Speed Freak
jessrayo's Avatar
Good Stuff.
Ted.
There is a different intake air temp sensor just before the throttle body so it is reading accurate temps after intercooler and meth, just have the MAF before the meth. I guess injecting the meth into the intercooler keeps it more evenly dispersed throughout the air, may allow more methanol use. The dyno numbers here are with 91 octane pump gas and methanol.
This is the first methanol system I have had in a daily driver and I think it only starts to spray above 6 psi of boost but if I'm moving fast it will empty the one gallon of meth before I go through a tank of gas. Haven't put the car on the road course but I know there it will use all the meth probably with a half a tank of gas....it definitely is a meth addict. So far in the 5000 miles I've driven the car with turbos on it I've used about 12 gallons of meth. Its fine if I stay in town but if I put the car on the open road I have to fill the meth tank when I come home. One full throttle burst over 175mph will use about 1/3 of a gallon. I can't argue with the results though.... it will get up and run.
Old 08-01-2016, 01:05 PM   #36
JANNETTYRACING
Again I am not here to debate or say there is anything wrong with the way it is done.
It obviously works well.
I am just sharing technical info that may be helpful.
Ted.
Old 08-01-2016, 01:17 PM   #37
jessrayo
Speed Freak
jessrayo's Avatar
Ted.
It's all good, if I didn't have your comments I wouldn't know what to ask the builder....lol. I'm constantly learning more about all this stuff and just about the time I think I've got it kind of figured out GM comes up with a new engine....
Old 08-13-2016, 01:55 PM   #38
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
I agree on the placement of things on the kit. The tuner who did his car even expressed those concerns to AGP.
Joe@CPR.com is offline   Reply With Quote
Old 11-05-2016, 09:51 PM   #39
parish8
Drives: 17 SS a8
was meth installed for those dyno runs or after?
9psi for 550hp? something seems off to me with that.
Old 11-06-2016, 01:40 PM   #40
AGP Turbo
Drives: All things Turbocharged
These were some earlier leaning experiences with a different dyno and different tuner that left us with a number of problems that he couldn't remedy. He was commanding 13.5:1 at WOT
We took it to a better tuner who had no problem clearing everything up and getting the tune right and safe.
AGP Turbo is offline   Reply With Quote
Old 11-07-2016, 07:52 AM   #41
JANNETTYRACING
Well, if you read the Internet, your suppose to run DI motors at 13.5:1 with boost
Old 11-07-2016, 08:12 AM   #42
parish8
Drives: 17 SS a8
Since it has been brought up what is a good target a/f or lambda? I always went 11.5-11.8 on the ls stuff.
