NPP q's
Can a non NPP car be converted into a NPP.
Does the factory harness have the wires/connections installed and it's P&P? Would a tuner have to enable them in the ecm? Or must you order the car with it in order to have it if you went to an aftermarket set? |
Thanks!
Not the answer I wanted, but points me in the right direction. I've had the electric cut outs in the past and they've been junk. Everything from getting "out of time" (one open and one closed), butterfly shafts snapping, motors dying, etc. that I'm afraid to go back to them. I'm thinkin' the factory valve set up would be way more reliable + it turns itself on and off based on load. No switches or key fobs to jack with when it is "show time"... |
You’re welcome. Sounds like you will get it all together. Good luck.
