Camaro 1LE 2018 Rear Bumper Popping out
1 Attachment(s)
Is there fix to this known issue on the Camaro's of the rear bumper popping out? please see picture below.
:thanks::thanks::thanks: |
Pull out the tail light and ziptie it
Thank you for the reply. Is there an alternate option then zip tie?
Someone on the other thread did it through warranty... they just pushed on the bumper and tighten the bolts again... and it didn't help.
Zipties are your best option. |
Wanted to update you all. I did the zip tie and it worked. Thank you!
I thought I saw somewhere there was dealer adjustment/TSB to mount bracket that addressed this ?
It looks like it might be missing a clip in that square hole
^^This. That sticks out more than usual.
Be curious if anyone has taken off bumper cover to inspect.. root cause.
Think I would rather do the zip tie mod then let the dealership screw it up.
