Good fluid is key. SRF is great as it needs only one bleed per season (15-20 days). If unavailable, Willwood makes very good DOT4 racing fluid which is very close to SRF specs (and seems equally expensive).
I might add, that if you are running the Motul (I do), you need to bleed the brakes a bit after each track event.
