10-03-2019, 01:55 AM | #1 |
Drives: 2018 ZL1-1LE Join Date: Aug 2019
Stock pads?
I'm about to do my first track day with my ZL1-1LE. How good are the stock pads?
I'm impressed that apparently the Nürburgring car was running stock pads. What should I expect? The only brake mod I've done is run Motul 600. I was going to use Castrol but there seems to be a nationwide shortage. This is not my first time doing a track day. I've done 50 -75 in my '03 Z06 over the past 4 years. I will be running at Willow Springs and I expect the temperature to be in the low 80s. |
10-03-2019, 05:41 AM | #2 |
Drives: ISO ss 1le Join Date: May 2018
Plenty of threads on this already...
I was impressed overall on the stock compound, however i did get them to fade a little bit after 20-25 mins on track. I have tried the DTC60 all around and now i am on Gloc r12 which fall right in the middle of 60 and 70’s. Easy to modulate and great overall bite without too much initial torque to upset the vehicle. |
10-03-2019, 07:26 AM | #3 |
Thanks for the reply. How much are those pads, and where do you purchase them?
10-03-2019, 07:32 AM | #4 |
Sorry if there are already threads on this as well, but do most guys run OEM rotors/rotor rings?
10-03-2019, 11:01 AM | #5 |
i would use the stock pads the first time and if you feel the need to upgrade after you can !
10-03-2019, 03:55 PM | #6 |
Drives: Tracks: 18' ZL1 1LE Join Date: Mar 2018
Had no issues with stock pads at WSIR. I think stock pads are fine for pretty much all tracks in CA.
18' ZL1 1LE Red Hot track toy
Castrol SRF Ported TB/Rotofab dry intake AWE Track w/PLP APR GTC300 wing / Singular Endplates ASC Splitter / PA tunnels MFR Engineering Custom Diffuser Race Louvers Fender Vents APEX SM10 & ARC8 For sale: 2018 OEM ZL1 1LE Wing 12' Nissan GT-R SOLD |
10-03-2019, 04:59 PM | #7 |
Drives: 2018 ZL1 1LE Join Date: May 2019
Ive almost gone thru an entire pad set and I have zero issues. Good fluid and lines that I will sone be upgrading will solve most fade issues, but I never have had a hint of fade. Pads can be had for about 300 a set on amazon.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
10-03-2019, 05:39 PM | #8 |
I'm surprised by how inexpensive the stock pads are, so I'm hoping they will work at the tracks I run (Willow, Buttonwillow, and Laguna Seca).
For the poster who said he got fade, you mean pad fade (pedal getting harder) and not fluid fade (soft pedal), correct? Also, do you guys run stock rotors/rotor rings? |
10-05-2019, 01:32 PM | #9 | |
This car benefits most from driver mod.
10-05-2019, 04:49 PM | #10 | |
10-06-2019, 11:02 PM | #11 |
That's weird. So you have to buy both the rotor ring and the hat together each time the rotors need replacing?
What is the best place to buy them? |
10-07-2019, 03:17 PM | #12 | |
Drives: around in circles few days a month Join Date: Mar 2019
I run Sonoma, Thunderhill and Laguna Seca with stock pads. They work well for me. I'm new, 8 days, and seems like a brake fluid flush helps keep the brakes from fading.
Avatar photo credit: Dito Milian at gotbluemilk.com
10-31-2019, 07:03 AM | #13 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Does anyone have a link or a product number for the stock front brake pads? Thanks
10-31-2019, 08:23 AM | #14 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Good prices, nice delivery options and 5% discount offers after your first or second purchase. I get both the rotors and stock pads there. Cheers! |
