Old 05-15-2024, 04:45 PM   #1
BatMobileLT1
BatMobileLT1's Avatar
Drives: 2023 Camaro LT1 M6
M6 (TR6060) just started over rev'ing when shifting and clunk noises
I've had zero problems through ~15K miles w/my M6 LT1 (and really love having a manual again( but last time I drove it for a while all of sudden on the way home on every shift it over rev'ed the engine and when the clutch was fully depressed it made clunking noises. Shifting to neutral the rev's return to normal (as well as once in the next gear).
I thought it might be rev-matching feature (which I use) issue, but I disabled it and the problem was the same.
I have appointment to have my dealer work on it next week (and plan to have GM roadside assistance tow it there) but just curious if anyone heard of something like this or has any ideas what it could be?
This really bummed me out as it had seemed so reliable until now - Thanks!
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers
BatMobileLT1 is offline   Reply With Quote
Old 05-15-2024, 08:53 PM   #2
Kamero6
Drives: 6th Gen LT1
You could have a broken pressure plate. As soon as you put some pressure on the clutch, barely pressing it, it starts to slip and the revs shoot up.
You need to adjust for that happening, but needs to be fixed.
Kamero6 is offline   Reply With Quote
Old 05-15-2024, 10:20 PM   #3
BatMobileLT1
ok - yes, that seems to match my symptoms pretty closely.
Will see if dealer confirms next week and go from there.
Thanks!
