Old 05-10-2024, 07:39 PM   #1
avenger79
Drives: 2020 Camaro LT1
275x40x20 on front of LT1
ordered some new wheels and tires for the Camaro.
rear 305x35x20 on 20x10 wheel with 23 mm offset
front 275x40x20 on 20x9 wheel with 35 mm offset
the rears seem fine but fronts are definitely hitting the strut.
anyone running these sizes and how?
avenger79 is offline   Reply With Quote
Old 05-10-2024, 08:01 PM   #2
White1SS
White1SS's Avatar
Drives: White 2024 1SS M6
35 seems like a lot of offset for the fronts. Are you rubbing in height or width ? In either case a spacer might help.
White1SS is offline   Reply With Quote
Old 05-11-2024, 07:32 PM   #3
Gen6cyl
Gen6cyl's Avatar
Drives: Chevy Camaro 2021 ,rs, v6, manual
You need at least 10 mm more space on front.
B6 dampers, x pipe, mbrp axel back
Gen6cyl is offline   Reply With Quote
Old 05-13-2024, 09:09 AM   #4
avenger79
rubbing in height. I think I may have to send these back and go with different sizing on both front and rear.
my rear tires were 305/35/20 on a 20X10 wheel
fronts were 275/40/20 on a 20X9 wheel
seems like this is 1" taller than stock. (I should have checked before ordering)
I would like to keep the 305's on the rear (can fit 305/30/20) but not sure what to get for front. was thinking 265/35/20.
Anyone know if that will work without a spacer. still the 35mm offset.
