05-07-2024, 07:48 PM | #1 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
DUAL WIDE BANDS ???
Hey guys... with the recent install of my GESI 4.5" 1700HP rated cats... that were installed with V bands, I had the shop weld in another Wide Band 02 bung on the opposite bank... in order to future proof for a second wide band gauge. I've read this is NOT necessary, but perhaps a wide safeguard for higher HP boosted cars.
Question.1 - Who else has two? Question.2 - If you display both, how do you? Question.3 - Are there any gauges that blend the two banks? or do you simply display both individually? Question.4 - Anyone done this with a Banks iDash? Thanks in advance.
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
05-08-2024, 12:19 PM | #2 |
Drives: HBM ZLE Join Date: Aug 2017
#2 probably have a gauge for each one, I'm using the aem so you'd need a gauge pod for both.
#3 display each one individually which will tell you how far off they are from each other and if you have a failure might be able to save it. Don't think blending will do much as your averaging them when you want to know exactly where each bank is at. #4 If the banks will display afr or lambda, might be able to wire them both into that gauge and only need one but I don't have the banks so not sure if it is capable. My plan is to eventually run both aem's in my dual a pillar pod and then my aeroforce in a vent pod. Will probably pick up an IDash down the road because they display a lot of info at once as opposed to the aeroforce which only shows 2 pids at once I believe. |
05-08-2024, 12:26 PM | #3 |
Thanks for the feedback Aaron, Just found this... Also assume we could run them both through the Banks iDash once you purchase there expensive hub?
05-19-2024, 07:16 AM | #4 |
I am surprised that no one here is running (2)... Is it really not beneficial then? or is it just a cost issue?
05-19-2024, 11:04 AM | #5 |
Drives: ‘23 ZL1-1LE Join Date: Mar 2023
I can’t speak from experience, with regard to the Camaro, however more information is a benefit in my opinion rather than less. Especially for diagnostic purposes, assuming the devices are actually high quality and are known to give out accurate information. Bad data from poor quality sensors can be almost as bad as no data….
05-19-2024, 05:58 PM | #6 |
Drives: 2019 ZL1,2016 2SS, 2017 320d F30 Join Date: Dec 2021
why would you run one for each bank?
If you adjust fueling or spark times it applies for both banks the same. Both banks will probably run slightly different anyways.
excuse my english
05-19-2024, 06:12 PM | #7 | |
Hoping bigger brains will chime in on this I am asking because the iDash allows to monitor both, and there are other products on the market that track both so that tells me the cost benefit and demand has already been evaluated. I assume a stock car would not be needed, but perhaps valuable for those pushing the limits more?
05-19-2024, 07:58 PM | #8 | |
It’s nice to see stuff on the iDash but datalogging on HP Tuners is where it’s at. Since the AEM 30-0334 makes it SO easy to integrate single wideband readings into your VCM Scanner, that’s what we all live with lol. If iDash could integrate the dual wideband readings into the scanner logs during a run it could certainly be helpful…but really not day-to-day helpful over a single wideband UNLESS you were having issues between driver and passenger side banks that isn’t picked up by the ECM (heavy rich/lean conditions and/or misfires are detected by the ECM)… so not sure how often the duals would really be that useful. Just my 2 cents.
Yesterday, 12:05 PM | #9 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
i run 2 wideband sensors. My aem gauge is just kept in the glovebox. My other one is hooked to my gauge on the defrost vent. I make use of the 2 while logging.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
