Old 05-06-2024, 09:44 AM   #1
C Man
Drives: 2018 White Convertible Camaro ZL1
Alignment Camber - 0 for Best Traction?
My car is currently set up with a track alignment and hence a more aggressive Camber.
However, when the car is launched and the rear is loaded, I assume the Camber increases even further.
While great for the track, this doesn't seem to be good for a hard launch as less of the rear tires are connected to the road.
So I'm thinking that if I'm not tracking it.... I should decrease the Camber as much as I can. What do you guys thing? And are there any other alignment aspects I should change to make sure the car is set up properly for this?
White 2018 Camaro A10 Convertible ZL1
C Man is offline   Reply With Quote
Old 05-08-2024, 10:07 AM   #2
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
I had my car aligned for drag racing with as little camber as I could get on the stock parts and with just a little bit of toe in. It definitely helped launching.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels
1.45 4.01 6.07@120.74 9.28@153.43
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild
jlaudio11 is online now   Reply With Quote
Old 05-08-2024, 12:41 PM   #3
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
That's the typical drag setup, 0 or close to it camber.
