04-18-2024, 08:38 AM | #1 |
Wheel Backspacing?
I see all of the Camaro Wheel specs like diameter, width, offset, and bolt pattern, but what is the BACKSPACING on the stock 20x8 and 20x9 wheels?
I am looking to buy a set of custom Snowflake Wheels for my Camaro Trans Am Conversion, and am having issues finding sources (other than the megabuck Forgeline's TA3 in the pic) that make them in 20", and need backspacing info to get them built correctly. Last edited by hesster; 04-18-2024 at 08:49 AM. |
04-18-2024, 10:26 AM | #2 |
Drives: 2010 Camaro SS manual Join Date: Feb 2022
Here is a calculator you can use to convert backspace to offset and vice versa.
https://tireswheelsdirect.com/wheel-...ce-calculator/ And here are the calculated values for the stock SS wheels: Front: 20x8 Offset: 35 Backspacing: 5.9 Rear: 20x9 Offset: 40 Backspacing: 6.6 Edit: remember to post pictures when you get the wheels installed! .
2010 Camaro SS, LS3 + 6spd manual.
1975 Volvo 242, 357SBC + 6 spd manual. 1978 Blazer offroader with LS1, 1-ton axles. |
04-18-2024, 10:34 AM | #3 |
Well, I did find this about the 9 inch OEM wheels..
https://www.bing.com/search?q=2011+c...ecs&FORM=QSRE4
04-18-2024, 10:38 AM | #4 |
Some more info on the OEM wheels that was posted on the forum by 9ball, who used to be a member back in the day..
https://www.bing.com/search?q=what%2...&ghacc=0&ghpl=
04-18-2024, 07:06 PM | #5 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
This is what I found on several sites...
04-19-2024, 06:59 AM | #6 | |
04-22-2024, 12:25 PM | #7 |
Ahh bro, that's lookin better all the time!
