04-15-2024, 09:41 PM | #1 |
LTH installation tips
bought my SS in 2021 Sep and now finally looking to get a set of kooks LTH with high flow cats, currently have Corsa catback, Ported LT2 IM and rotofab CAI.
A local shop quoted me 900$ to install headers and 600$for street tune. I think I might just do the labor work myself and take the car to the shop if I F***** up...(hopefully not) I know this has been talked a lot, but can someone share some tips for LTHs?
THANKS EVERYBODY FOR THE READING AND HELP!
2021 Camaro 2SS Summit White
Kooks 1-7/8 LTH with high flow cats, Corsa Extreme+ variable, Roto-Fab CAI, GPI Ported-LT2 IM, LT5 95mmTB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can. |
04-16-2024, 05:30 AM | #2 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
1. MSD wires are great and fit better than factory with headers. We always recommend MSD's with headers. Anytime we have a client with headers develop a random misfire, its a stock plug wire for various reasons. Never with the MSD's.
2. No. If quality Stainless Steel you don't need any ceramic coating. 3. Why is it beneficial on a street car? 4. no, just move it away from the headers and secure it to the frame. 5. If your LT2 IM is ported to the 95mm then go with it, if not just do the ported 87mm. 6. If you have a remote tuner tuning the car they will need the data. If you're having it dyno tuned and they have a wideband then no. 7. If you've never installed headers before, you're in for quite an adventure. It's not easy for someone who isn't at least somewhat experienced. But it can be done. You need to get the car up very high in the air(like 3-4 feet) to get the headers in or you will have a miserable time.
GM Gen V Calibrator
04-16-2024, 11:14 AM | #3 | |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
Aftermarket plug wires can save you future headache. Plenty of good ceramic wires on the market, take your pick. No, if you are worried you can get a starter blanket for 30 buckls from jegs or summit. Its because it makes the install easier, no other reason. I did, you dont have to just make sure it fastened down securely and wont move around. Maybe some additional throttle response and 5-10hp. The butt dyno wont know. Your turner, if remote will likely require one (if he is worth a damn.), if you want to get it tuned by a shop, you shouldn't need one. Id skip the throttle body and run e85 if you have it available. Its worth just as much power as the headers you are adding. |
04-16-2024, 09:45 PM | #4 |
Thank yall for the tips! does 21 SS starts come with a head shield next to it already? I am debating if I should install headers myself on jack stand and cuss for the total 8 hours or pay 900$ to have the shop install them for me.......
04-17-2024, 07:49 AM | #5 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
ceramic coating will help with heat transfer and less heat in the engine bay, stainless or mild steel no difference with heat transfer
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake |
04-17-2024, 08:08 AM | #6 | |
Snackbar Tuning
If you have never worked on cars before or have only changed a battery or something, don't have a good set of tools, and have no way to get the car 3+ feet up in the air, then you're going to have a bad time and get frustrated and wish you had spent the $900 to let someone else do the work. Although I would say for $900 that would only make sense if its the ARH long system. If it is just headers connecting to the factory exhaust at the front of the car, then that is a bit expensive for labor.
GM Gen V Calibrator
04-21-2024, 09:33 PM | #7 |
well i decide to take it to another shop for 500-600$ that I was quoted. the shop said the OEM start heat shield is actually really efficient, do I need to add on additional heat tape or something? but idk if it can be added onto the existing heat shield
04-22-2024, 07:46 AM | #8 |
Drives: 23 2SS 1LE Join Date: Feb 2019
1. I think MSD wires is a good option
Yes, there are other options as well, and even just adding heat shields to stock wires is good enough for most people. 2. do i need the high temp wrap or ceramic the headers in case they might burned the starter? Need? No. But for a few hundred bucks to keep the heat in the engine bay down and minimize the risk of burning wires and other parts, I think its worth it. 3. I heard people say its also benefitial to install the BMR motor mounts? no clue..... Not really, its also unrelated to getting headers installed. 4. Do i need to add more heat shield wrap on the passenger side hardness? Not necessarily, but it wouldn't hurt. You can also relocate it which a lot of people do. 5. Since I am just one TB away from FBO, should I go for Lt5 TB? or would stock TB limit a lot of HPs? Considering its pretty much the cheapest of all the FBO parts, why not? You can pick up a few extra horsepower but it also increases throttle response and helps out more up top in the RPM range. 6. Do I need AEM wideband?.. not sure what I can do with the AFR reading From my understanding, a remote tuner needs that info, but in person tuning will not. Talk to your tuner to verify. 7. Anything else? Make sure you have EVERYTHING you need before getting started. Its not the hardest thing in the world but its definitely not recommended for beginners. You have to get the car pretty far off the ground. At least Kooks have decent fitment so its not AS BAD of a headache, but its still a pretty big task. Watch some how-to videos all the way through before you really decide this is what you want.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
04-22-2024, 09:14 PM | #9 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
When I did my install, I pulled the starter heat shield off and wrapped one side of it with heat tape, then re installed it. I live in Arizona and never had an issue with the starter in 5 years.
