04-15-2024, 12:03 PM | #1 |
Drives: 2019 Camaro SS 1LE Join Date: Feb 2024
Kill switch for fuel system on 2016+ SS, SS 1LE, ZL1, & ZL1 1LE
How the switch works: The toggle switch acts as a disconnect for the fuel pump wiring. When the switch is in the off position, the car will continuously crank without starting up. If the car was recently on prior to attempting to start the car with the switch off, the car will likely turn on and run until the fuel empties out of the line, this is approximately 3 seconds or so. The intention of the switch is to prevent thieves from driving your car away. MAKE SURE to turn the switch back ON before attempting to drive the car so it won’t give you a CEL. If you or a thief attempts to turn on the vehicle with the switch in the OFF position, the car will issue a CEL. Just use a obd2 code reader and clear the code and continue with your day. Items needed: Toggle switch 16ga wiring Butt connectors Electrical tape Wire cutters Wire strippers Wire crimps Wire loom Drill and drill bit (to mount in a specific spot, not needed if using an existing hole.) The wiring diagram can be found here : https://www.camaro6.com/forums/attac...4&d=1669240808 |
04-15-2024, 12:15 PM | #2 |
Drives: 2024 Camaro 1SS M6 Join Date: Nov 2023
Very much appreciated information, thank you for such a detailed guide. Anything we can do to stop these thieves is welcomed!
04-15-2024, 12:34 PM | #3 |
Drives: LT1 Join Date: Mar 2022
Neat thanks for the info! I have a couple questions that I hope you can answer.
When I unlock the car, I hear what I assumed was the fuel pump working for a few seconds before starting the car. If this is true, do you have to turn on the fuel pump and let it run for a few seconds before starting the car, or is the noise I'm describing related to something else? |
04-15-2024, 01:50 PM | #4 |
Drives: 2023 Camaro ZL1 Join Date: Jan 2023
Great first post contribution to the forum. Thanks.
2023 Camaro ZL1 6MT Summit White
04-15-2024, 02:24 PM | #5 | |
No. Just flip the switch on if you want to drive the car. No need to prime anything. I’ve been using this for over 6 months now with no issues. I also am FBO e85 and track the car heavily. |
04-15-2024, 07:57 PM | #6 |
Sweet, thanks again!
04-17-2024, 06:01 AM | #7 |
Drives: 2019 2SS Convertible Camaro Join Date: Mar 2012
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness K&N AirCharger Cold Air Intake Sound Tube Delete |
05-15-2024, 11:10 PM | #8 |
Drives: 2023 Camaro Convertible ZL1 A10 Join Date: Mar 2023
This is a great Idea and easy.
05-16-2024, 06:58 AM | #9 |
Petro-sexual
AWESOME!!! Thanks for sharing!!!
