03-27-2024, 10:37 AM | #1 |
Drives: 2011 Camaro SS Join Date: Feb 2024
Oil message on dash
So started my 2011 SS and the message can up low oil need to fill I checked and the oil level was good on the oil stick any help would be greatly appreciated.
03-27-2024, 01:05 PM | #2 |
maybe you need a new one of these. check the wiring too.
12603781 https://www.rockauto.com/en/moreinfo...t=5700&jsn=644
03-27-2024, 01:27 PM | #3 |
Ok thank you i was thinking life a oil pressure sending switch but i will try this and see if it fixes it. Thanks for your help.
03-27-2024, 02:30 PM | #4 |
I had no idea these cars even had a Low Oil notification/light
03-27-2024, 02:36 PM | #5 |
Me either until I found this level/temp sensor in my pan. I've never seen a light , but I think it shows up on the DIC.
03-27-2024, 02:38 PM | #6 |
You said the display said "Low oil need to fill" , that doesnt sound like a pressure warning to me. They would tell you to shut the car off immediately if I remember right.
03-27-2024, 07:09 PM | #7 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Even my 02 Silverado has an oil level sensor on the side of the pan. Pretty common on LS.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-27-2024, 09:51 PM | #8 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Good to know I guess but the dipstick is still my friend!
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
03-28-2024, 03:07 AM | #9 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
A while back I had only put in like 4 quarts of oil in my car to start it and flush it, on the display it said low oil but didn't say shut the engine off.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-28-2024, 06:30 AM | #10 |
It doesn't say it when oil level is low, only when there's no oil pressure. Different sensor.
