03-22-2024, 12:30 PM | #1 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
Kill switch wiring question (pic)
I picked up what I needed to wire in a hidden kill-switch, and I THINK I know where I'm wiring it to, but I wanted to ask to see if someone has a better idea.
I'm thinking that in the engine bay fuse box, the starter relay and starter fuse are located there and the fuse would be the easiest (LEAST likely to mess up!!) place to wire the switch. I want to pull the fuse and use two wires in the box, then move the fuse to a different location. Then run two wires into the passenger compartment and connect them to a hidden switch. I bought 30 amp fuses and a 30 amp switch (since the factory fuse is 30A), along with a marine fuse holder (since the fuse will be more or less exposed). Below is a picture of the engine compartment fuse box, with the relay ("X") and fuse ("ARROW") marked. Comments or suggestions?
Don M
Supercharged LGX + 6 speed manual = FUN!! |
03-22-2024, 03:27 PM | #2 |
Drives: Chevrolet Camaro Join Date: Feb 2020
Not sure I like the idea of the 12v fuse wires passing through the firewall, too many rub points to cause issues later on. I would grab the latch ground from the starter relay, break it with your hidden cabin switch. Dont see the need to hide the fuse at that point either.
03-22-2024, 03:49 PM | #3 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Please don't post up too much info on the kill switch stuff. The thieves are on the internet too.......trolling for cars. Regardless of how you hook it up, the hidden switch won't be too hard to find if we talk about it on here.
GM Gen V Calibrator
03-22-2024, 04:31 PM | #4 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
This. 100%.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
03-22-2024, 08:12 PM | #5 |
Drives: 2020 SS 1LE Join Date: Aug 2020
Agreed! 1000%!
03-23-2024, 09:53 AM | #6 | |
Electrical Engineer
I agree that the starter relay ground is a much better approach, smaller wires. I posted about this in another thread
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
03-23-2024, 09:58 AM | #7 | |
Electrical Engineer
Install four toggle switches: make some of them dummy switches, or require a combination (like a code) using N.O. and N.C. contacts. Use multiple methods: Make thieves look for multiple solutions. Once our community adopts one of the dozen solutions we're discussing, the thefts will drop off and they will move to easier targets.
03-23-2024, 11:26 AM | #8 |
Camaro #4
I have a manual transmission, will that alter where I make the cut for the switch? P.S., I'm planning on a 2-stage kill switch, where two separate actions need to be taken to star the car.
Don M
03-23-2024, 11:58 AM | #9 |
Camaro #4
I looked at your suggestions again, and I was thinking of splicing into the Violet/Gray wire that activates the starter relay in the (under hood) fuse box (where I put the red dot).
Thoughts?
Don M
03-23-2024, 02:30 PM | #10 | |
Drives: 2000 WS6 Join Date: Dec 2014
Pin 15 on the black BCM plug under the driver's dash. See my DIY thread for more info. Still getting around to a schematic. |
