dave@hennessey
Old 03-08-2024, 10:33 AM   #1
hesster
hesster's Avatar
Drives: '10 C5 SS, '77 Bandit T/A
Rear Axle Nut P/N & Torque?
Anyone know what the correct Part Number and Tq is for the Rear Axle Shaft Nut on a 2010 1SS?
I read that they should not be reused, and I researched the forum threads but the recommendations for the Part Number are all over the place, and the Torque is stated at 85 Ft Lb and/or 199 Ft Lb (I think this is the correct torque).
Also not finding a P/N when searching the GM Parts Supply outlets like GM Parts Giant and others. Rock Auto lists a "Spindle Nut" from Dorman OEM #11611687, is that correct? The other PN I see is 11611234?
Or Gezzz - anyone just reuse them and add a little Locktite?
hesster is offline   Reply With Quote
Old 03-08-2024, 10:40 AM   #2
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
GM 11611687 is what I'm getting, I have always been told the axle nut is 199 ft/lbs. I wouldn't be afraid to reuse axle nuts if they are in good shape, little blue loctite and you should be set.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 03-08-2024, 10:55 AM   #3
ABM2SS
Drives: 2010 SS M6 ABM
The 11611687 Part number is correct. I usually replace them, but like NoDakZ/28, wouldn't be afraid to re-use them. I don't own a torque wrench that reads to 199 ft/lb, so I just tighten them to what feels like 200ish ft/lb. haven't had an issue in the 293,000 miles I've logged on it so far.
ABM2SS is offline   Reply With Quote
Old 03-08-2024, 10:59 AM   #4
hesster
hesster's Avatar
Thanks Guys - I mistakenly removed them when changing Rotors on my current Bandit Conversion Project. I DID reuse them when changing Axle's on my other 2010, and never gave it another thought.
So these look like new, and will use some LT Blue.
Now I hope the park brake will hold the axle for the 199 Ft Lb of Torque!
Old 03-09-2024, 01:01 AM   #5
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I'm not sure I would want to reuse them. But I'm thinking on a stock engine maybe it's not a big issue. I always go to the dealer to get mine.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 03-09-2024, 07:45 AM   #6
hesster
hesster's Avatar
So I was looking at suppliers for 11611687, which is M24x1.5 Nut. However, the nuts I have and removed used a 32mm Socket, not a 36mm!
"M24 (24mm) Thread Size. 19mm Nut Thickness (H) 36mm Socket Size (J)"
So are there some differences on these 2010 SS Camaros, or the spindle thread size is the same but the nut replacement went from 32mm to 36mm??
I know on my other Camaro 2SS I had to buy a 36mm socket, but this 1SS is not 36mm?
Found this thread - https://www.camaro5.com/forums/showthread.php?t=507919
Old 03-09-2024, 08:12 AM   #7
fz4k98
Drives: 2013 1ss
I did a little experiment on my ss related to single use bolts for the rear calipers. The left side got new bolts and the right side reused the current bolts. The left side was able to achieve the correct torque plus angle measurement and the right was not. I reused the front bolts and they were not able to achieve the angle too.
A bolted joint is in tension from the bolt acting as a spring. A reused bolt acts like a spring that has been stretched and not returned to relaxed.
All that said, all bolts are still tight after two years, so theories and real world are not always the same.
fz4k98 is offline   Reply With Quote
Old 03-11-2024, 08:03 AM   #8
NoDakZ/28
NoDakZ/28's Avatar
Caliper bolts are tty and should not be reused.
2014 1LE - Sold
Old 03-11-2024, 09:35 AM   #9
hesster
hesster's Avatar
And that is a whole 'nother discussion, almost bordering on comical at some point. https://www.camaro5.com/forums/showthread.php?t=364972
I just ordered the Axle nuts, 36mm, and assume even though I removed mine which are 32mm, the spindle size is the same and the 36mm is now the replacement.
We will see.
Old 03-11-2024, 01:20 PM   #10
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
My 2010 had the 32mm but I agree they changed to 36mm at some point. 1LE and ZL1 are 36mm as well. The only torque spec I have ever seen on the nuts is 199# and I have reused the nuts many times, especially the ones you stake into the grove on the axle. Once it's staked, it's not going anywhere. After 2-3 uses the metal where you stake it gets a little suspect, so I do change them occasionally.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
