01-25-2024, 08:11 AM | #1 |
Drives: 2023/2SS/1LE/RadiantRed/A10 Join Date: Jul 2022
Strange Redline
This morning I was getting breakfast from a cold start and on the way home I turned the corner, gave it a little punch because the roads were a little wet and I wanted I little fish-tail for funzzys; nothing extreme. However, my rpm’s went uncharacteristically all the way up to peak redline and would not drop. I was in touring mode so it freaked me out. I switched my auto to manual mode and shifted to 2nd and that released the throttle letting the rpm’s drop. Must have been at max redline throttle for a good 3-5 seconds. Wtf was that?
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
01-25-2024, 08:23 AM | #2 |
Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
If you blipped the pedal all the way down, sounds like you went into "Competitive Shift Mode." Aka- beast mode, lol
Previously Owned:
2018 Silver Ice Metallic Camaro R/S 1992 Dark Teal Camaro R/S 305 V8 |
01-25-2024, 08:42 AM | #3 | |
Strange Redline
Shouldn’t that not happen when I’m in “tour” mode though? Also, I thought that when you blip it in sport and track, it stays just below redline. Sent from my iPhone using Tapatalk
01-25-2024, 08:54 AM | #4 |
Good question regarding Tour mode, I've never tried it in Touring. But it should definitely stay below redline, so maybe there's another explanation. I'm sure someone here will have some insight.
Previously Owned:
01-25-2024, 09:20 AM | #5 |
Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
Are we talking well into the redline, like 7k plus? Or right at the 6500 line?
01-25-2024, 09:46 AM | #6 |
Long hauler
Can confirm it only activates in Sport or Track
2016 1LT v6 - Totaled Happiness: Infinite |
01-25-2024, 10:03 AM | #7 |
Thank you sir
Previously Owned:
01-25-2024, 10:52 AM | #8 | |
Strange Redline
As far as it goes. I was seriously freaking out. If I hadn’t manually shifted it, I don’t know what would’ve happened. What was also weird was that it was like it was in neutral too. I wasn’t accelerating while this was happening. Sent from my iPhone using Tapatalk
01-25-2024, 11:58 AM | #9 | |
I personally don't like to use it.
Previously Owned:
01-25-2024, 02:22 PM | #10 |
This is an issue, nothing to do with competitive mode that keeps rpms in the meat of the powerband and shifts just fine. Apparently the A10 didn't want to upshift automatically, and OP had to "help it out" using manual mode.
I'd pull the codes first to see what the ECM/TCM thought had happened.
01-25-2024, 02:24 PM | #11 | |
Previously Owned:
01-25-2024, 02:27 PM | #12 | |
I’ll get a reader. Do the codes store long? I didn’t know codes would come up without a check engine light. Sent from my iPhone using Tapatalk
01-25-2024, 02:33 PM | #13 | |
Some trivial codes can go away, but hitting redline and the TCM not commanding a shift (if that's what happened) on a stock car is definitely serious IMO.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 01-25-2024 at 07:57 PM. |
01-25-2024, 04:14 PM | #14 |
Long hauler
Closest I can relate is downshifting to a stop then when I go again in auto mode it hangs first gear more than usual, were you in manual mode just prior? Although mine just goes up to like 5k rpm and not redline
