Old 01-20-2024, 07:09 AM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Arrow 10 Rib CONVERSION ???
Hey Team, Just curious who here has done a 10 rib conversion? Wondering how long it look to install, and where you are getting the belts from... Any down sides aside from the $1k cost?
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can
Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster
ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar
DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 770rwhp 815rwtq @E55 13.5psi
SOCAL.M6.ZLE is online now   Reply With Quote
Old 01-20-2024, 07:47 AM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Pretty easy upgrade, couple hours of work to do the THPSI setup. 10 rib isn’t needed at your power level but the LT5 tensioner is a nice upgrade for more travel and stronger tension. Will be good if you decide to crank up the boost down the road.
Old 01-20-2024, 08:03 AM   #3
SOCAL.M6.ZLE
Thank you sir... I am planning on purchasing the Katech Dual Drop in Pumps, when they release the plug and play harness in the next few weeks, along with a Big Gulp.
With the extra lowside capacity, ill be running straight E85, and figured id also bump the lower pulley to add another pound of boost...
So when looking at lower pulleys, I saw the 10-rib kits, and thought that it might be time to upgrade... I am pretty sure, Ill be happy with 850rwhp +/- and wont need more than that...
Old 01-20-2024, 08:37 AM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
I installed this DSX upper idler bracket with 8-rib belt, which eliminated any slip
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct.
1116/967.
1.35/9.25/151 at 3500 ft. (only one pass)
15" conversion/MT ET Street R 325/50R15.
Old 01-20-2024, 12:50 PM   #5
Joshinator99
Famous last words haha! Far be it from us to try to coax you into more boost….
Old 01-20-2024, 02:20 PM   #6
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
where do you find the LT5 tensioner?
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 01-20-2024, 03:23 PM   #7
Joshinator99
You cannot just run the LT5 tensioner as the bolt pattern is different. TooHighPSI CNC cuts out the specific bracket you need out of billet aluminum. I have a pic or two in my build thread.
Old 02-05-2024, 12:37 PM   #8
Bangkok_ZL1
ZL1 Believer
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
i might be interested in this since i bought the supercharger head spacers. 5 mm doesn't sound like a lot. But it makes a huge visual impact as well as all the wiring harnesses are significantly tighter, And obviously the belt will be a close fit also. So a tensioner that has a bit more throw would be nice. I'm sure it will help with temps though. Today, February 5th it was like 93...
Bangkok_ZL1 is offline   Reply With Quote
Old 02-06-2024, 05:45 AM   #9
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Sorry to get off topic but how was the spacer install. I want to do this but can't find much info about it anywhere for some reaaon.
Old 02-06-2024, 07:29 AM   #10
Joshinator99
You should start a new thread about that since this one is about the 10 rib conversion.
