12-10-2023, 06:21 AM | #1 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Stabilizing rear end
So winter is here and time for some more upgrades. I’d like to know if anyone has done anything to stabilize the rear end “sway” that seems to come in 3rd and 4th gear under hard acceleration? I’ve got about 750 to the wheels now and I’ve snapped the rear end loose with tire spin in 3rd multiple times. But even when it doesn’t snap loose…I feel this sort of back and forth swaying going on. It’s a little unnerving. Speed climbing rapidly and also knowing it could break loose. Just would like to stabilize the rear end some more.
My guess is that this has something to do with the rear cradle and the softer bushings they put in from the factory to control noise. Which…don’t get me wrong…I love the quiet cruise of the Camaro and I don’t want a ton of NVH. But also think I need to get things a bit more under control back there too for safety. Rear cradle bushings? Control arms? What have people done? |
12-10-2023, 07:01 AM | #2 |
Drives: 2013 zl1 vert Join Date: Dec 2018
first what tires do you have? I'm at the same hp level as you and don't break the tires loose. I'm running the Nitto r2 and have the bmr toe rods and trailing arms. I'm also a convertible which has the long braces that connect to the front cradle and the body. I think those bars help a ton with the cradle. With all that said I did order Pedders cradle bushings and front radial arm inserts.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
12-10-2023, 07:13 AM | #3 |
I have Nitto tires as well. Can’t recall at the moment exactly which. But they are the 295 or 315 ZL1 width. I also have a ZL1 rear end with 3.73 rear end which is why I think it’s breaking loose. Geared a bit.
12-10-2023, 08:48 AM | #4 |
Drives: 2013 1ss Join Date: Jul 2012
You should also check the rear alignment for toe and camber. These settings can make a big difference in handling and tire spin.
12-11-2023, 07:11 AM | #5 | ||
GPI Sales Consultant
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
12-11-2023, 11:23 AM | #6 | |
Here is a video of the rear OEM cradle bushings moving all over the place that acammer was talking about. A lot of us have done this mod including myself, and man what a difference it made in the "solidness of the rear! Got rid of all my wheel hop!
12-11-2023, 11:59 AM | #7 | ||
Consider my full weight stick car cuts consistent 1.5x 60' times with no suspension mods other than the sub-frame bushings - I think that says a lot for how important those are, and also how much less important some of those other suspension mods are. I'm not discounting them, and they are on the to-do list, but I haven't found where I see much of a defection or toe issue with the stock stuff once the sub-frame is well controlled.
12-11-2023, 01:11 PM | #8 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Cradle bushings in on my todo list this winter. That video should sell anyone who has reservations on the idea of if it's worth it.
12-11-2023, 01:52 PM | #9 |
Yes sir guys!!! I did this mod after chatting with Jordan at JDP Motorsports, and if you know them, they track several cars Camaro's and Vettes competitively. They know what is going on!! Like Andrew said, after installing them I noticed a huge difference in how "tight" it was back there when I drove her out of the work bay. Wow. The rest of my suspension is all still stock except for the Pfadt racing springs. With the solid mounts AND the addition of the 1pc aluminum DS, she really puts the power to the wheels now!! And I mean, right now!! One of the best mods I have ever done!
12-11-2023, 02:02 PM | #10 |
Then imagine having the bushings plus the convertible brace bars also. lol
12-12-2023, 06:07 AM | #11 | |
12-12-2023, 09:52 AM | #12 | |
12-13-2023, 07:23 AM | #13 |
Thanks for the input guys. I definitely need cradle bushings. Will probably go with the poly ones. After watching that video…I’m convinced my cradle is deflating heavily under big pulls.
02-06-2024, 12:01 PM | #14 | |
Drives: 2015 1SS 1LE Join Date: Sep 2015
Suspension is 1" BMR drop and Bilstein struts, BMR trailing arms, poly diff bushings. Strangely enough this rear end wiggle never happened until I installed BMR rear UCA bushings, UMI adjustable rear toe rods, and BMR delrin rear subframe bushings....all 3 installed at the same time. Alignment was done at that time and tires are good. I did increase rear negative camber from -1 to -1.7 for better handling on the road course. Rear toe is 0 to a tad toed in. Thrust angle 0.01. I've checked every bolt in the rear and they're tight. I'm scratching my head. If toe is changing dynamically I suspect the UMI toe rods. Could the ferrule be oversized for the bolt? I'm reaching here. I hate to drop $300 on a new set of BMR adjustable rear toe rods just to find out it doesn't help. Last edited by Fanch1LE; 02-06-2024 at 03:01 PM. |
