Old 11-16-2023, 05:49 PM   #1
dbs1
Drives: 2017 ZL1
Adding sc to the tow truck /fueling question???
2018 Denalli 1500 w/6.2. Currently has tune, headers, 3.73 gears and a Tx Speed stage 1 cam (after the dod ate the cam).
Thinking of adding a Whipple 3.0 sc and wanting to make sure I’ve got the fueling covered. TxSpd says the cam has a 38% fuel lobe. Rwhp should be 650-675.
Anyone know if this would have enough fueling capacity to not have a problem?
dbs1 is offline   Reply With Quote
Old 11-16-2023, 06:03 PM   #2
ZLRob
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Is it an LT4 or LT1 engine? If it's LT4, the stock fuel pump should handle all that but you would probably want to throw a JMS on it or something the likes if you want to handle E85 on it.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ
Old 11-17-2023, 07:54 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The engine in your truck is basically like a LT1 in a Camaro SS. Pump gas isn't ideal with boost but your cam will help. Fueling is going to depend entirely on how much boost you plan to run which won't be much imo. 7-8psi tops and that isn't really utilizing the Whipple 3.0. You would be better off to go with a LT4 supercharger at that boost level.
I don't believe GM put LT4's in any trucks...the 2018 truck 6.2 is a L86 similar to the LT1.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 11-17-2023, 09:07 AM   #4
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I think the injectors and HPFP will need to be upgraded. Maybe King can chime back in but I swore the L86 fueling was even smaller than LT1 fueling.
Old 11-17-2023, 11:28 AM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
You are correct the trucks have smaller in injectors than the Camaro LT1
This gentleman will need an LT4 pump and injectors.
And We stock them.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 11-18-2023, 08:45 AM   #6
KingLT1
KingLT1's Avatar
And We stock them.
Ted.
This!
2016 NFG 1SS A8
Old 11-18-2023, 12:09 PM   #7
Joshinator99
This!
