11-03-2023, 04:32 AM | #1 |
Drives: 2015 Z28 Join Date: Feb 2022
Anyone know where I can get a new LS7 block?
Long story short, took my Z28 on some European trackdays last year.
At roughly 170 mph on the autobahn one of the sportcats collapsed, leading to head gasket failure and a piston cracking. Got that fixed but car overheated again shortly afterwards, have rechecked and theres a crack in one of the bore liners Looking at getting it resleeved but if this isnt possible Ill need to replace the block, funnily enough they arent exactly common here in the UK |
11-04-2023, 05:41 PM | #2 |
Build Date - Dec 08, 2014
Drives: 2015 Z/28, #1007, Black A/C Stereo Join Date: Oct 2015
I would suggest contacting any of these reputable companies. They all specialize in LS engines. You may need to be prepared to take the LS block of your choice and modify it to be an LS7.
https://sdparts.com https://www.texas-speed.com/ https://www.mastmotorsports.com/ https://americanheritageperformance.com/ |
11-04-2023, 07:05 PM | #3 | |
Drives: 2015 Z/28, 2007 HHR Join Date: Jan 2014
11-05-2023, 03:58 AM | #4 |
Nice one, thanks guys. I really want to stick with the LS7 if I can as its not really an Z28 without one, hopefully sleeving will work but it snot going to be cheap either way
11-05-2023, 04:14 AM | #5 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
You live in UK,these are possible in FI.
https://www.kivinummiracing.fi/index...torit/ls7-7-0l https://laukkanenmotorsport.fi/c1086...es-bare-blocks |
11-23-2023, 03:48 AM | #6 |
Drives: Honda Civic Oriel Join Date: Nov 2023
Replacing the LS7 block is a viable option if resleeving is not possible. The LS7 block is not commonly found in the UK, but there are a few sources that can provide you with a new one. Some reputable sellers include Katech, Mast Motorsports, and Ed Rinke Performance.
11-23-2023, 04:37 AM | #7 |
Cheers, its at the machinist being resleeved atm, fingers crossed it will work!
11-24-2023, 05:35 PM | #8 |
Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
I bought a cracked LS7 block off of a racer friend of mine. Was cracked from a valve snapping off. The crack went into the water jacket. His local machine shop wouldn't touch it. I paid him $200 for it. I took it to my world class machine shop Jan-Cen Racing Engines and Mike Janis himself came out to take a look at it. He said that he's repaired way worse blocks and that it shouldn't be a problem. I will let you know when I get it back, what the total dollar amount was.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C 1980 Z28- resto-mod project 1979 Y84 Trans Am 1986 IROC-Z |
11-26-2023, 07:11 PM | #9 |
Drives: ZL1 Join Date: Oct 2012
Another great shop is Livernois, they have a very nice machine and fabrication facility which can more than likely easily handle your issue. If that fails I would highly recommend going with a RHS block which will handle whatever you throw at it especially in a natural aspirated setup.
11-27-2023, 03:30 PM | #10 | |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
https://www.chevrolet.com/performanc...ylinder-blocks
11-27-2023, 03:37 PM | #11 |
Drives: 2013 ZL1 Join Date: Nov 2018
Well THAT sucks
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
11-28-2023, 07:57 AM | #12 |
Tell me about it, Id just spent the best part of $5K getting the head gasket - that we thought was the problem - fixed as well
If the liners dont work I dont want to think about the potential cost, I cant imagine getting a block shipped from US to UK is cheap and if I put anything other than an LS7 in its not a Z28 anymore ........ |
11-28-2023, 10:00 AM | #13 |
Excuse my earlier post, I overlooked that you were located in the UK, however there are Chevrolet dealerships in the UK I think that you should be able to order the block that trickskier provided if it comes to that.
