Vararam
Old 10-23-2023, 05:40 PM   #1
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
Need a Favor ya'll
Could someone please give me 2 dimensions for the Tunnel Brace?
center hole to center hole, if someone has one handy, I have no lift right now and I'm getting my CV Axle replaced tomorrow.
I'm making my own out of 1/2" Aluminum on a CNC Mill so I be able to get some 3" pipes down there.
I would really appreciated.
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 10-24-2023, 06:07 AM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I have one somewhere but won't have time to dig until tonight.
Sent from my Pixel 5 using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
larry_g is offline   Reply With Quote
Old 10-24-2023, 04:10 PM   #3
larry_g
larry_g's Avatar
13-7/8" center to center and
3-3/8" center to center
Old 10-24-2023, 05:21 PM   #4
Infidel67
Life's just a Ride
Infidel67's Avatar
Thank you Larry, You're the Man
Old 10-24-2023, 05:26 PM   #5
Infidel67
Life's just a Ride
Infidel67's Avatar
I will make a few and post em on here, maybe some free giveaway's.
I got some Aluminum which I will machine and can Laser cut some .119" mild steel for the brackets and tubing and weld em on.
It's just freaking crazy the prices on these!!
I can also Powder Coat but only in Caterpillar Black, Yellow and John Deere Green lol
Old 10-25-2023, 10:14 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Very cool sir! Yeah, I ended up buying the BTR one..
1JEWLDSSRS is offline   Reply With Quote
Old 10-26-2023, 12:18 AM   #7
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
I did the full delete… Say no to Tunnel Braces…
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 10-26-2023, 09:15 AM   #8
Infidel67
Life's just a Ride
Infidel67's Avatar
wow, really?
but but I'm using this nice and shiny Aircraft Aluminum making it look all pretty lol.
I check out your suggestion and see how it feels !
Old 10-26-2023, 09:27 AM   #9
Caveman_SS
Will Cave
Caveman_SS's Avatar
Drives: 2010 Victory Red 2SS LS3
I'm not running one right now, but only because my exhaust needs adjusting because it vibrates against the brace lol. I didn't really know what it was for when I took it off. Is it to give the car a little more rigidity?
Caveman_SS is offline   Reply With Quote
Old 10-26-2023, 10:06 AM   #10
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
I have the BMR subframe connectors and they are tied together with the tunnel Brace. Makes a big difference in rigidity. They do create clearance issues in a lowered car like mine, but...
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is offline   Reply With Quote
Old 10-26-2023, 10:16 AM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I had that problem when I had my stock brace with the 3" exhaust. Stacked a few washers between the brace and the floor and problem solved!! Then I bought the BMR one.
Old 10-26-2023, 10:33 AM   #12
Caveman_SS
Will Cave
Caveman_SS's Avatar
Good idea, I might try that. Thanks!
Old 10-26-2023, 10:45 AM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I think I used either 3-4 on each bolt. Worked like a charm!! Gave it just enough clearance so when the exhaust moved any, it didn't touch. Good luck!
Old 10-26-2023, 04:24 PM   #14
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
wow, really?
Yup, really, and pushed a bit more than stock power through the chassis for a number of years with no issue…
Dual 3.5 inch exhaust and a 4” one piece driveshaft all nicely tucked away… Removed a substantial portion of the aluminum (“heat barrier / sound deadening”) shielding from the tunnel, mostly towards the back… as well…
There’s nothing wrong with well crafted shiny or even dull (well crafted) bits here and there… I made quite a bit of effort to craft nice pieces that ended up under my car, never to be seen outside the shop… However, I discarded the tunnel brace about the time I installed the MGW shifter… Never noticed any issues as we graduated the car up in power, or racing intensity…
I suppose if that big aluminum transmission crossmember won’t support the tunnel spread, that sheet metal brace won’t either… I’m sorry I have no image to show…
