10-04-2023, 01:29 PM | #1 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
MRR FS02 19x10" Square Wheel Setup
19x10 et27. I will include both 5mm and 7mm spacers for the fronts, with 7mm the wheels are exactly the same as the OEM SS 1LE spec offset and the the rear is exactly the same as the SS 1LE offset without any spacers. 7mm will require longer front wheel studs, 5mm will fit oem wheel studs and only be 2mm further in.
Often people buy lower offset rears to avoid using spacers but then the rears poke. This fitment is SS 1LE OEM as far as the offsets matching the outer edges of the wheel, but with a square rotatable setup. This is ideal for a daily driver, winter setup or track setup for LTs. Ideal size is 285/35/19, I ran 265/40/19 Miche4lin PA4s. 295s and 305s will fit too. They are in good shape, no curb rash at all, some minor rock chips that don't mar the aluminum. Satin black color is easy to touch up if desired. Please see pics, the pics make the imperfections look worse than they are. The MRR FS02 wheels were their high-end line and went for about $2600. They are flow-formed wheels with quite a bit of intricate machining that make them look high end. https://www.mrrwheels.com/blogs/news/fs02-wheels Asking $1300, (NOW $1100) they are boxed-up and ready to ship using Apex wheel shipping boxes as shown in pics. Actual shipping charged, likely $150. Local pickup fine too of course. PRICE LOWERED TO $900!
11-10-2023, 02:03 PM | #2 |
Still Available!
These would make for a great street or winter setup for any Camaro!
01-30-2024, 02:10 PM | #3 |
BUMP! Lower Price: $1100.
04-15-2024, 02:21 PM | #4 |
$2600 wheels for $1100, make me an offer!
I will include both 5mm and 7mm spacers for the fronts, with 7mm the wheels are EXACTLY the same as the OEM SS 1LE spec offset and the the rear is exactly the same as the SS 1LE offset without any spacers. 7mm will require longer front wheel studs, 5mm will fit oem wheel studs and only be 2mm further in. Often people buy lower offset rears to avoid using spacers but then the rears poke. This fitment is SS 1LE OEM as far as the offsets matching the outer edges of the wheel, but with a square rotatable setup.
05-14-2024, 01:32 PM | #5 |
Ok, $900. 19x10 square setup with the exact same fitment as OEM SS 1LE/ZL1!
