10-02-2023, 07:47 PM | #1 |
Drives: 2020 SS 1LE Join Date: Jan 2023
QuickJack ELX6000 or XLT6000 Models
Has anybody successfully used the QuickJack 6000ELX or 6000XLT models with their camaro? I had liftpads on the car that measure ~69in apart which is slightly outside of the 66in lift spread of the 7000EXT.
My concern is if the 86in frame length of the 6000 models is able to fit under the car and lift it with enough clearance. I could make the 7000EXT work with additional hardware, im just trying to see if the 6000 series work as well which would make life a little easier. |
10-02-2023, 08:44 PM | #2 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I use the BL-5000SLX without any problems. Max distance on that is 60in(lift point spread) and I'm not maxed out but I am close. Frame length is 70 inches.
10-03-2023, 07:18 PM | #3 |
Drives: 2024 ZL1 M6 Join Date: Sep 2018
I have the 6000 and it works great. They are long, but work perfect. I had the 5000 before and it wouldn't reach the front jacking point so had to use the middle one and the rear. I bought the 6000 to use on my Hellcat Redeye since it was a yacht. lol The 6000 reaches the front jacking point with ease, is heavier built, and seems more stable.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp, Jet Hot Coated ARH 2 inch LT's, Stainless Works NPP, Too High PSI Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, 295/30-315/30, BMR springs, BMR Cradle lockout, AAD Billet Control/Trailing arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
10-03-2023, 08:17 PM | #4 |
L8ap3x
I use the 5000TL with the Camaro. Had it up many times.
No issues.
"Manuals win hearts. Automatics win races."
2018 2SS 1LE HBM 6M |
10-04-2023, 05:58 AM | #5 | |
10-04-2023, 06:26 AM | #6 |
Drives: '18 ZL1 1LE Join Date: Sep 2021
I have the 6000ELX. I like it because you use the front most jacking point. That makes me feel a little better. I'd buy it again but there are some downsides.
The side skirts and ride height on a ZLE (not sure if the same ones are on a ZL1) necessitated using the ZL1 add-on jack pads. If I wanted to just use the rubber blocks of the quickjack lifting straight on the pinch weld, the iron frame of the quick jack would start to deform the side skirts at the front jack point before the blocks were engaged enough to lift the car. It might have been fine, but it bothered me. I already had the jack pads on the middle and rear jack points, so I just moved the middle to the front. However, due to the size of the block, the edge of the block starts to deform the side skirt when engaged to the jack pad. This is probably fine, but to fix that I cut a small section out of the underside of the side skirt, to allow the rubber block better clearance. Can't ever see the difference, and now it raises without deforming the side skirt. Additionally, the iron frame of the 6000 is a little beefier to handle the extra weight. On my ZLE, it doesn't fit under the car. So I drive the front wheels onto 1x8 boards. Then slide the quickjack under it. I would do this all again because imagining all the weight of the engine so far in front of the lifting point makes me nervous. It's not much trouble to make it work, but it might be more than some want to go through. The length of the 6000 ELX quickjack is fine, it just has to be moved quite close to the rear wheels. |
10-04-2023, 07:08 AM | #7 |
Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
10-04-2023, 08:27 AM | #8 | |
My primary concern was the clearance of the overall frame length and it being able to get under the car without the tires being in the way, but it looks like it should be good to go with the information provided. |
10-04-2023, 09:24 AM | #9 |
Drives: 23 2SS 1LE Join Date: Feb 2019
I was JUST looking at which QuickJack to get for my 1LE as well. Looks like the 6000ELX is the best bet.
I am still confused on if it slides under the car or if you need to drive up on it due to the length and clearance issues though. Also unsure if those low profile or pinch weld block/pucks need to be added if I have the ZL1 lift pads already.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
10-04-2023, 10:15 AM | #10 | |
Drives: 23 ZL1 20 Jeep GC Join Date: Aug 2020
23 ZL1-A10-Summit White
10-04-2023, 10:27 AM | #11 |
Drives: 23 Camaro 2SS Join Date: Dec 2022
I have the 5000TL. I use it on a stock 23 SS. I installed the pinch weld pads. Don't try to lift the car without these installed, you will destroy your side skirts.
I use a block from the quickjack set to make contact with the Pads on all four corners of the car. Very confident with the system. Do not drive on the QuickJacks. You slide them in place once your car is parked on a level surface. |
10-04-2023, 10:34 AM | #12 | |
10-04-2023, 10:58 AM | #13 | |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
10-04-2023, 04:54 PM | #14 |
The rubber blocks sit in metal trays within the jack. Without them in the tray, there's no stable surface to contact the car. So you need them even if you have the ZL1 add on jack pads installed. The jack pads (on 4 corners) sit on the 4 rubber blocks. Nothing else touches the car. Don't use the quickjack without 4 zl1 add on jack pads installed. Quickjack does sell rubber blocks specifically for use with pinch welds, but they're extra $ and you'll still probably run into issues with the rocker panels.
I'm getting the car up on the jack in the next few days. I don't mind taking some pics of how the 6000ELX works with a ZLE if it would help anyone considering a purchase. Just let me know. |
