08-25-2023, 05:46 PM | #1 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
Tachometer bouncing up and down randomly
Has anyone had their tachometer on both their driver display dash and heads up display, intermittently, bounce up and down randomly with absolutely nothing to do with how the car is actually being driven? In other words, everything sounds, and feels totally fine…
My dealership doesn’t seem to have any good ideas as to what the cost could be
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
08-25-2023, 05:49 PM | #2 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
Sounds like a tachometer sensor issue.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
08-25-2023, 06:08 PM | #3 |
Thanks I’ll inquire about this.
For a little more information, that I kilometre bounces anywhere from 500 RPM to 4000 RPM, and sometimes it will do it for 20 minutes straight
08-25-2023, 06:27 PM | #4 |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
I've had this happen on my Toyota Tundra. Check to make sure all your grounds are good and solid. Believe it or not, a bad wheel speed sensor can also cause this.
ΜΟΛΩΝ ΛΑΒΕ
08-26-2023, 12:52 PM | #5 |
Drives: 2022 ZL1(FEA suspension) Rapid Blue Join Date: Apr 2019
..... and it continues
08-29-2023, 08:29 AM | #6 |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
It's a ground issue. Double check ALL the grounds.
08-29-2023, 08:38 AM | #7 |
Ground issue as mentioned above. Common on these cars.
2016 NFG 1SS A8
08-31-2023, 06:41 PM | #8 |
Thanks. I’ll let the dealership know, they did come up with something else, apparently an internal service board on this, but I imagine checking the grounds still makes sense
*Edit* So the internal service bulletin is about taking the grounds, looks like everyone is on the same page, thanks!
09-05-2023, 10:33 PM | #9 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
There was a TSB about this if I remember.
