Old 08-20-2023, 02:25 PM   #1
lynyrd
lynyrd's Avatar
Drives: Camaro 2.0 LT 2018
Send a message via Skype™ to lynyrd
Reprogramming ethanol
Good morning,
Is it harmful to drive permanently on 100% ethanol, or do you have to fill up with E98 from time to time?
I had programmed it on ethanol and the engine grazes, when I came back from programming, I was running on gasoline and it started to graze.
I contacted the person who did the programming and they replied "you have to put the original filter back" (I had installed a K&N filter and I had no problem).
Do you think he's right, it's the air filter causing the chatter?
I was told that the 2.0 turbo engines were not receptive to ethanol, is that true?
2018 Camaro 2.0 LT Turbo, Conversion to ethanol E85, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights
lynyrd is offline   Reply With Quote
Old 12-10-2023, 08:38 PM   #2
Bluey666
Drives: camaro ss
No, it is already a very mature solution for LTG engines to run on ethanol fuel.
Bluey666 is offline   Reply With Quote
