08-10-2023, 05:24 PM | #1 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
Starter heat soak
Just got my motor back it’s a 427 dart iron block so it runs a bit hotter than stock. Need recommendations on a good starter that won’t heat soak. Having issues with frequent hot starts. Letting it cool down a bit it will start.
08-10-2023, 05:55 PM | #2 |
https://www.camaro5.com/forums/showt...504199&page=10
Not sure if you saw this or not. I had to install two in my Camaro, the one in the trunk and one from the bell housing to the body. Took care of the problem.
08-10-2023, 06:24 PM | #3 | |
08-10-2023, 06:31 PM | #4 | |
https://www.summitracing.com/parts/dei-010402
08-10-2023, 07:24 PM | #5 | |
08-10-2023, 08:19 PM | #6 |
Drives: 2013 1ss Join Date: Jul 2012
How old is the current starter? I replaced mine this year without any other changes like grounds or new battery or cables and it now spins like new. Mine was a 13 camaro with 64k mikes.
08-10-2023, 10:54 PM | #7 |
08-11-2023, 09:13 AM | #8 |
My original lasted 7 years before it crapped out. Bought another one from Summit Racing and it only lasted 4 years. I think it might have been a reman unit, I didn't pay attention when I bought it. Just replaced it with a new OEM one from my Chevy dealership, and with the 2 new ground cables she starts up way better than when the car was brand new!! Even hot!! Instead of it going rer rer rer zoom, it goes rer zoom!! Even hot.. The starter when the car was brand new NEVER did that, ever. People used to ask me why it stars so slow, and I would tell them, that's how it is. Little did I know about the grounding back then!
08-11-2023, 09:20 AM | #9 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
I still have 9 of my ground cables for sale. 2 cables with a bolt and lock washer for the frame is $50 Paypal goods and services. You can see my for sale post in the classifieds here. Many happy forum members rocking my cables. PM me if you would like payment information.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
08-11-2023, 09:22 AM | #10 | |
08-11-2023, 09:41 AM | #11 |
08-11-2023, 10:15 AM | #12 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
I never had a moment's issue with starting, till I built my 416ci stroker ,and it immediately did what yours is doing . As soon as it got to operating temp would crank real slow and not start till cooled off. I read another guy's post ,don't remember who ,that said its not heat soak at all its the ground points not having the paint removed .
When I pulled the negative ground in the trunk I found just what he said the only thing grounding was the threads of the bolt ,and they always get oxidation and start to loose ground. So I ground the paint off down to bare metal and reconnected and sprayed some corrosion X on it . I did this to all of my ground points and added a new ground from my engine block to the frame and never had a problem since. https://www.camaro5.com/forums/showthread.php?t=615106. Hope this helps! Ps I'm still running the original starter with 170,000 miles on it.
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
08-11-2023, 06:09 PM | #13 | |
08-11-2023, 08:32 PM | #14 |
IJEWLDSSRS , YOUR WELCOME the other gent deserves the credit, I just can't remember who it was !
