07-22-2023, 01:11 PM | #1 |
Drives: Camaro RS 2016 Join Date: Feb 2022
2016 RS rear brake calipers upgrade options?
Hi, everyone
I haven't found any upgrade options for Gen6 RS rear brake calipes whatsoever, I was looking for a 4 piston options, but no luck. Not that it was a crucial update, but in case you know a good option please share your thoughts and experience Thank you |
08-07-2023, 09:27 PM | #2 | |
Drives: 2020 3LT Camaro 3.6L 1LE Join Date: Feb 2020
Not going to find it. E-brake and ABS software wont work. GM did that on purpose. |
08-08-2023, 09:16 AM | #3 | |
Drives: 2023 Camaro LT1 M6 Join Date: Dec 2022
Rainfarer - you said its not crucial upgrade - so just in case you'd be interested in cosmetic only upgrade, I posted this on good caliper cover option I found that improves the looks significantly: https://www.camaro6.com/forums/showp...17&postcount=2
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers |
08-16-2023, 03:24 PM | #4 |
Drives: Chevy camaro Join Date: Jul 2019
I was about to say, I put the fronts from a 50 anniversary on my 1LT and was going to do the same for the rear. Well darn. I guess we have to put 18"s on there with some slicks.
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears. |
