Old 06-26-2023, 08:58 AM   #1
Rwink90
Drives: 2015 Camaro ZL1
Rear Suspension
Hey all, I have a 2015 camaro zl1. My rear struts were making noise and seemed a little weak. So I need to replace. My car has the magnetic ride option. Checked with GM, but parts were discontinued. So I installed an aftermarket system from BMR suspension but doesn't have the magnetic ride capability. Couldn't find anything that did. Kit came with coil over struts, lower control arms, and toe links. I also had to purchase a new sway bar system. I got everything installed and aligned. But I noticed a couple days ago, when I went to pass someone and a message came up saying speed limited to 85mph. Looked into the owner manual and it says that message will come up when the suspension has an issue. It's going to since I took off the original system. But I was wondering if there is any way around it? Do I need to take it to a GM shop and have them reprogram something or need to remove the fuse for the suspension module? Please help? Thanks
Rwink90 is offline   Reply With Quote
Old 06-26-2023, 01:05 PM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Here is one way to fool the sensors, I'll try to find the other option. I believe you can buy these pre-made.
https://www.camaro5.com/forums/showthread.php?t=589911
HOJO is offline   Reply With Quote
Old 06-26-2023, 01:07 PM   #3
HOJO
HOJO's Avatar
And this.
https://afepower.com/afe-control-rel...ock-delete-kit
Old 06-27-2023, 03:43 PM   #4
Rwink90
Ok thanks. I'll try that and see what happens.
Old 07-24-2023, 06:59 PM   #5
xdamxincx
Drives: zl1 blk
cant this feature be turned off in hp tuners?
xdamxincx is offline   Reply With Quote
Old 07-25-2023, 06:41 AM   #6
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
HP Tuners can't access the SCM.
FasNuf is offline   Reply With Quote
Old 07-25-2023, 11:36 PM   #7
xdamxincx
Drives: zl1 blk
if i just do back shocks can i just fool the rears only?
rear suspension problem
