06-19-2023, 08:08 AM | #1 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Holy Hell... Major issue need advice
So I took the car to an auto shop. They told me the motor locked up / Seized. The engine has oil. What would cause an engine seize?
Only thing I can think of is maybe a rod or piston? But I would find that odd because I shouldn't be anywhere near that range for that to be an issue? Any advice, suggestions on how to best approach the issue?
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
06-19-2023, 08:15 AM | #2 |
17’ Hyper Blue 2SS
Kinda a shot in the dark, most common would be a failed oil pump. What was it doing before kicking the bucket?
06-19-2023, 08:15 AM | #3 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
A 2020, hum.
Let me call the dealer I sold mine too, and see what caused it. Might not be the same but maybe a starting point t
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
06-19-2023, 08:18 AM | #4 | |
To clarify, the mechanic used the term "Engine Lock" rather than "seizure" He said he tried to turn it but wasn't able to.
06-19-2023, 08:41 AM | #5 |
Doing more research, there is a thread on here, that talks about spun bearings. Another source I found talks about valves getting thrown into the engine which can cause a lock up. Other research says maybe a broken timing belt. I don't know to be honest. I'm the farthest thing from a Mechanic.
I am not sure it is applicable. I see this being the worse possible scenario, and I'm just trying to find out just how bad the situation is.
06-19-2023, 09:23 AM | #6 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
A bunch of 2020’s were shipped with a bad batch of valve springs. Typically the failure would occur in under 1000 miles but I’m sure some could have went longer. Yours could have shipped with a bad batch of valve springs which would have a caused a valve to drop.
06-19-2023, 09:28 AM | #7 |
17’ Hyper Blue 2SS
I think 2020 was the notorious year for valve throwing with the LT motors, but I wanna say that was within the first few thousand miles.
06-19-2023, 09:36 AM | #8 |
Really bummed out by this. I'm not sure what to tell the shop, or if I should just tow the car back to my house until I can figure out what to do.
06-19-2023, 09:36 AM | #9 |
Drives: 2019 Camaro 1SS Join Date: Apr 2019
Going to be hard to determine without further troubleshooting. I would pull the plugs and look for damage on them. Might narrow it down to a cylinder if parts were bouncing around in a cylinder due to valve train issues. If it is due to a spun bearing that locked up the rotating assembly, will probably need to pull the oil pan to confirm.
06-19-2023, 09:38 AM | #10 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
It's a 2020 do you not have a drive train warranty on it still?
06-19-2023, 09:41 AM | #11 |
17’ Hyper Blue 2SS
06-19-2023, 09:47 AM | #12 |
And insurance won't cover something like this.
06-19-2023, 09:48 AM | #13 |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
06-19-2023, 09:58 AM | #14 |
Gotcha...! I didn't look at Fluke's signature. Bummer...! it sounds very expensive. Best of luck with it though.
