06-13-2023, 06:13 AM | #1 |
Drives: Camaro Join Date: Jun 2016
Need help
Hey guys , my 2014 ss has be totalled am looking at repairing it , am based in the UK so I Havnt got access to alot of the parts or it would cost a hell of alot to ship the parts over
I have found a 2013 v6 2LT auto , front subframe with suspension set up , I know the suspension set up is different . Would I be able to do a straight swap and put this on to the 2014 SS or atleast just the subframe alone ? Thanks guys will attach a picture so you can see the damage I will be using the V6 front fender and door aswell shouldn't have any issue with these should be a straight swap ? |
06-13-2023, 07:42 AM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
The front subframe should be the same but the struts and springs will be a different rate and height. Pretty sure the sway bars are different too, but now would be the time to upgrade all those pieces anyway.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
06-13-2023, 09:36 AM | #3 |
^^^ Yep, what he said..
