06-03-2023, 05:03 PM | #1 |
Drives: 2013 zl1 Join Date: Apr 2023
Mag Ride time bomb?
So are the mag ride on our gen 5s zl1 just a ticking time bomb?
Been reading about mag ride issues and parts availability..etc. What I was wondering is it a matter of when not if. Ie do mag rides fail for most gen 5s and then we have to convert to air alternatives? Are gen 6s better or would those experience same issue? My new to me 13 zl1 with 26k miles is wonderful but now I am wondering how much more I will need to stick into if this is inevitable? |
06-03-2023, 05:56 PM | #2 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
06-03-2023, 09:35 PM | #3 |
06-03-2023, 10:05 PM | #4 | |
I can’t answer your second question because I don’t know what type of coil over your would go to and there’s endless options, but most have tried to come back to a mag strut if they can find them except those doing serious tracking. Just enjoy it while you have it, it won’t be around for every and neither will you.. |
06-03-2023, 10:51 PM | #5 | |
Perhaps I am just not following…. So if mag ride fails.. Is mag ride no longer offered on vehicles so parts will be limited? If so, and I do a standard coil over…do you lose all the zl1 performance mode suspension capabilities? Just trying to understand..thanks again |
06-04-2023, 08:19 AM | #6 | |
06-04-2023, 08:27 AM | #7 |
Drives: 2013 ZL1 Join Date: Sep 2021
Like anything mechanical eventually they will fail. GM is no longer offering replacements but there are plenty of solutions you just lose your push button for adjustability and ride quality. Hopefully someone will come up with an aftermarket mag ride or offer a rebuilding service but don't hold your breath. My suggestion is enjoy the car and don't worry about it.
FYI My 20 year old 29,000 mile Corvette also has mag ride and they are still working perfecly. |
06-04-2023, 08:28 AM | #8 |
Drives: 2013 ZL1 Camaro Join Date: Feb 2018
Just enjoy it while you have it, it won’t be around for every and neither will you..[/QUOTE]
This has been my view since replacing the rears but every time I drive it I find myself thinking about this issue. Diminished pleasure has me thinking about selling it. |
06-04-2023, 09:34 AM | #9 | |
Indeed.. this is what I also think… makes me consider selling and upgrading to a newer year zl1 or switching to mustang Shelby. However, looks like those have magrides as well. What is typical cost of coil over mag ride delete on zl1 ? (I would not do it myself…) Assume if one starts going (leaking)…..do you need to replace all struts with coil over? Appreciate the advice |
06-04-2023, 12:55 PM | #10 |
Learner of things
Drives: 2013 ZL1 M6 coupe, black Join Date: Dec 2017
It's not cheap... several thousand dollars in parts and a couple days labor to do it right and re-align. I did mine and it was worth it. Have many many launches down the strip and tens of thousands of street miles since then and wouldn't go back. Went with dual adjustable coil-overs all around. Strange in the back and QA1 in the front. I would have gone with Strange for front also, but QA1s were available quick and priced right.
Only problem I have had is the shock sim modules failing prematurely, but luckily I have had great support and warranty on them from the mfr. (X-ineering). I suspect it may be heat or vibration killing them and no fault of the part.
2013 M6. Cammed, straight piped, 17# boost, E85. Tuned by CHenry Motorsports. 825rwhp @ 6450, 812 rwtq @ 3500. Stock unported blower, stock heads, stock bottom end, stock throttle body. Boost only, no meth, no nitrous
06-04-2023, 03:15 PM | #11 | |
So really…the magride system is - a ticking time bomb that is great while it lasts but will likely fail prematurely - there are really no long term magride replacement options - the coil over replacement options are expensive and results in loss of factory features So like $5k to replace magride with coil over replacement? Want to understand if this is worth sticking more money into or just moving to another performance car before the magride blows. I find it difficult to believe that GM would not have a Mag replacement option considering how recently magrides have been available on recent vehicles I guess shame on me for not researching this better before purchasing. I have always been a mustang fan…but I simply fell in love with the newer Camaro look and the relatively easy mods for the zl1 engine They just look badass.. Last edited by Ckmerc; 06-04-2023 at 03:36 PM. |
06-04-2023, 03:59 PM | #12 |
The cost to convert s all dependent on what you plan to do with the car and how its driven.
You can spend less than 1K in parts on a coilover conversion all the way up to the sky's the limit. You will also have to either but load resisters to fool the computer about $400.00 or you can make your own for next to nothing. Labor at a good shop should be 5-7 hrs + an alignment, not sure why the above poster said a couple of days. |
06-04-2023, 04:12 PM | #13 | |
So sounds like $4k or under for reasonable coilover magride conversion when system fails. Am I off base? |
06-04-2023, 05:51 PM | #14 |
3k total including labor would get you a nice adjustable set up.
