![]() ![]() ![]() Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Ill affects from Octane Booster?
Hey everyone, my tune requires the use of an octane booster for this shitty 91 we have here in Cali. Aside from changing the plugs a different shade of color, are there any other ill affects from running an Octane Booster on every fill up? Trying to stay as stock "looking" as possible is def a priority living in Cali, so going with a TooHigh setup would make me uneasy. Thanks for any input or suggestions!
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
Petro-sexual
It's said anything in the exhaust could get build-up. I never noticed much on my plugs, but I was just trying to blend to about 93-94. I ran RaceGas (orange - 1-32oz can per tank) and Professional Boostane to blend to about the same.
All say they're safe but no one makes a guarantee. I think the Boostane was a bit of a better buy, and a proven product, as RaceGas and VP's Octanium.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Can you get a jug of fuel from a race fueling and mix it per fill up? Kind like what they do with "89" octane in the east. Just a mix of 93 and 87 octane. But you would mix 91 and whatever? No full on race gas just mix it in.
Octane boosters are going to be $$$, which you already know and it freaks me out that the big fuel guys do not offer it. Like shell, bp etc...
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
![]() Drives: ‘23 ZL1-1LE Join Date: Mar 2023
Not sure where you live in CA, but my town has VP unleaded at the station. I’d rather back off a tune than rely on octane booster, but that’s me.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '20 ZLE Join Date: Jun 2020
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
Please don't take my next comments as anything negative towards Octane boosters...
I stopped using Boostane after a couple WB02 sensor failures and an Injector issue. I switched to water/meth and haven't had any of those issues repeat since (same or longer amount of time has passed). I have no way to directly tie these failures to Boostane other than the fact that they haven't repeated since I stopped using it. I was mixing 93 up to 98+. They work but I just don't think it is appropriate to use them every tank. Heading to an event like a track day or dyno event as an extra precaution against knock should be fine.
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
2016 NFG 1SS A8
#8 |
Petro-sexual
I think he's trying to be as mod' friendly as possible, because in CA, even law enforcement will stop cars for mods' without CARB-exemption. So - some people use strategies that minimize any visual cues of any modifications to the car. Being octane limited to 91, and with smog nazi's everywhere, it's hard to get power, so if you can get a few tens-worth of power through better fuel, that's one way to stay low on the radar.
I think if everyone uses that as a filter, the reasoning behind the OP's post might become a little clearer. JMHO.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
E85 tune or mix some E in to your 91 gas????
#10 |
![]() Drives: 2022 ZL1 1LE Join Date: Sep 2015
Hi all,
When I lived in Cali, I used to mix locally available 100 octane unleaded race gas in a percentage to up my shitty 91 to a less shitty 93. The car ran better for sure, but then, five years ago, it was $10.00 per gallon. No idea the cost now. I used available charts from the net for the mix ratio. Never had any issues at all. Sadly, the better fuel mix never helped the totally stupid off-idle stumble the ‘18 ZLE was stuck with from the stock ECU settings. I haven’t used anything but AZ 91 in my new ‘22 ZLE, as I really haven’t had tons of time to drive it. But it does run a lot better and stronger than my’18 did. JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!! 2021 F-250 FX4 2023 Hyundai SF Calligraphy |
#11 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
I've been running Race Gas literally since day 1. My outside exhaust tips are orange vs black. That's about it.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i use the torco octane booster ever track day no issues almost 40k going to get oil change and plugs changed next week so well see how they look
https://www.summitracing.com/parts/t...SABEgJSO_D_BwE
#13 | |
'20 ZL1 1LE A10.
#14 |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
I don’t use octane booster because I’ve heard of fouling spark plugs, O2 sensors, and cats.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
