04-24-2023, 10:12 AM | #1 |
Illuminated interior door trim
Good morning,
Could you tell me if in this room (see photo) Is the lighting integrated or is it in the door trim? Thanks.
2018 Camaro 2.0 LT Turbo, Conversion to ethanol E85, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights |
04-24-2023, 03:49 PM | #2 |
Long hauler
Not sure what you’re meaning, that photo has the spectrum lighting (illuminated door trim), the silver piece has a light tube that two led’s shine through at each end.
2016 1LT v6 - Totaled Happiness: Infinite |
04-25-2023, 05:26 AM | #3 | |
If I remove this silver piece, is the light tube part of the silver piece or part of the door trim?
04-25-2023, 07:39 AM | #4 | |
However, I'm not sure how exactly the wire connection to the door trim is made, never took mine apart completely.
04-25-2023, 07:43 AM | #5 | |
It is not possible to remove it from the silver coin?
04-25-2023, 09:35 AM | #6 |
Long hauler
I don’t think you can remove the tube from the silver trim, I remember being able to take out the LED’s as they’re only covered with a snap on plastic cover. The light tube itself was integrated into the silver trim. I believe the only point you can see the light tube at all on the other side is through two plastic molded pieces where the LED’s are placed
