03-17-2023, 12:06 PM | #1 |
Drives: 2015 Camaro 2SS/RS Join Date: Jan 2007
TruTrac Gear Oil
What brand is everyone using?
"Eaton recommends a petroleum/mineral based GL-5 80W90 gear oil for all Truetrac Differentials. Do not use Synthetic gear oil or friction modifiers"
2015 2SS/RS 6spd
Rotofab CAI,MGW Shifter, DSP Tune Kooks LT/HFC/Xpipe/NPP Mufflers 4:10's, Trutrac Solid Cradle Bushings, BMR Toe and Trailing arms |
03-17-2023, 12:34 PM | #2 |
Drives: 2011 2SS/RS Join Date: Feb 2016
The few people i know with the tru-trac just use the parts store non synthetic. I love my amsoil but they are only synthetic. When i go the swap, itl probably be top tear non synthetic by mobil.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
03-17-2023, 12:36 PM | #3 |
Hardcore Gearhead
Nothing special is needed with an Eaton Truetrac carrier. Being a helical LSD it doesn't have the friction modifier requirement a clutch style of LSD does so any good GL-5 lube will work fine. No need to use synthetic as a good petroleum 80W-90 will work perfectly. I personally use Valvoline or NAPA (same), nothing special is required.
Mike
2013 2SS/RS |
03-17-2023, 01:58 PM | #4 |
Drives: 2015 1SS 1LE Join Date: Sep 2015
I use Lucas or Valvoline, whatever's available on the shelf at the parts store that day.
03-17-2023, 03:30 PM | #5 |
Drives: 700 rwhp 2010 SS Join Date: Sep 2010
I used Valvoline basic 80w-90 in mine.
03-17-2023, 06:20 PM | #6 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
https://torcousa.com/products/rgo-racing-gear-oil
Run this in my Camaro and Pick up both True Trac equipped, I run the thicker weight in the truck.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
03-20-2023, 01:06 PM | #7 |
Thanks All. I settled on Lucas Oil SAE 80W-90 Gear Oil (LUC10043)
2015 2SS/RS 6spd
