Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 01-26-2023, 06:24 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
60 foot time
Hi all. I'm a little confused. I read talk about gears and 60' times and too low of a gear and you'll shift into 2nd before 60'. My question is, what is the concern if someone shifts into 2nd at the 58' mark vs 62' mark? Isn't all about your final E.T, or am I missing something?
J.D
Maroon 6.2L SS is offline   Reply With Quote
Old 03-03-2023, 11:21 AM   #2
hillshooter
Drives: 2015 Camaro SS commemorative
I think they are more talking about shifting at say 30' or 40'. 58 is close enough I would worry. WHat you do need to look at is a balance between SLR and trap gear ratio. You would want steeper to start but lower to finish. Which is why close ratio TH400's or powerglides are so popular.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 03-26-2023, 08:39 PM   #3
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
The very best way to get your car optimized at the drag strip is to tune it while you are there or have someone who knows how to do it with you.
Shift points have to be optimized based upon what converter/gear combo you are running, and since you don't launch the car on the dyno, your initial shift points from 1st to 2nd probably need some adjustment.
My car was cutting consistent 1.53-1.54 60' times on my initial tune.
Now at my local dragstrip, it will cut 1.49 after track tuning.
What this ended up for the ET was a drop from 7.2X in the 1/8th mile, to 7.1X, in good DA and good prep.
If only I weighed 130 instead of 230, I could run 6.9x.
The biggest thing though at the dragstrip is dialing in the light.
You can have a great 60', and everything tuned to perfection, but if you aren't cutting
0.1X or lower lights, you can and will lose to slower cars, and have no chance of beating a slightly faster car.
I'd much rather beat a car that runs 6.8, than post a PB ET, because I won the battle at the tree, and the race by a slim margin.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
