Old 12-19-2022, 08:57 AM   #1
BDay33
Drives: '23 2SS 1LE - Rapid Blue
Driving 1LE in EXTREME cold
Hey Folks,
Since I got my 1LE back in November, my family back home is wanting me to bring it during Christmas to they can see it. I've been reading some things that's making me start to question driving it back to Alabama for the holidays.
Since the 1LE has summer only tires, I'm fearful of cracks in the tire or other issues. It's supposed to around 15F degrees ambient when we're leaving Friday night, and lows in the 10s the whole weekend. We have a 2-hour drive Friday night. Staying overnight Friday/Saturday, car will be sitting outside, and driving another hour Christmas morning.
Thoughts?
'23 2SS 1LE in Rapid Blue found in transit
1100 Order Placed at Dealership - 10/17/22
Found another in transit - placed deposit and cancelled existing order - 10/26/22
Picked up - 11/5/22
BDay33 is offline   Reply With Quote
Old 12-19-2022, 09:03 AM   #2
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
and you think that's extreme? As long as you have the right tires, it's fine.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 12-19-2022, 09:13 AM   #3
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
I would not consider driving in those temps on stock 1LE tires. Regardless of tracking, traction will be non-existent.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 12-19-2022, 09:20 AM   #4
BDay33
For our area, yes it's extreme.
Did some more research and it sounds like Goodyear Eagle F1 SuperCar 3s will possibly have issues in the scenarios I mentioned. Looks like we're taking the Elantra this weekend...
Bummer.
Picked up - 11/5/22
Old 12-19-2022, 09:26 AM   #5
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Yes you definitely do not want to run those tires in those temps.
Old 12-19-2022, 09:49 AM   #6
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
I didn’t like running the Supercar3 in anything below 60’s due to traction issues. Michelin PS4S are the better option if running in cooler temps and rain.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 12-19-2022, 10:25 AM   #7
BDay33
So, I'm leaving the car here in Atlanta. I live in an apartment and park the car in a parking garage (obviously not heated). Windchill here Saturday morning is supposed to be like -5.
Should I consider going this week to get some winter tires put on? It doesn't get that cold here very often, but I'm fearful these tires sitting idle in the cold may crack. Or do they only crack from flexing while being driven?
Picked up - 11/5/22
Old 12-19-2022, 11:01 AM   #8
demonspeed
demonspeed's Avatar
Drives: Camaros
They’ll crack from just being in the cold. Put it on jackstands and bring them in to your apartment
10/13/22: 1100
Old 12-19-2022, 11:02 AM   #9
thewurzernator
Drives: 2022 2SS 1LE RAPID BLUE
do not operate those goodyears under 30 deg no matter what. see this TSB
https://static.nhtsa.gov/odi/tsbs/20...83781-9999.pdf
thewurzernator is offline   Reply With Quote
Old 12-19-2022, 11:05 AM   #10
SATINSTEEL1LE
Drives: 21 ZL1
I drove my 17 1LE through a Chicago winter. It was no big deal. Take it slow and use snow mode. Mine was manual obv. Easy to second gear start and crawl.
SATINSTEEL1LE is offline   Reply With Quote
Old 12-19-2022, 11:25 AM   #11
BDay33
From reading this, it sounds like the tires are only susceptible to cracks if the car is moving. I don't see anything regarding if the car is idle and not being driven.
Picked up - 11/5/22
Old 12-19-2022, 12:05 PM   #12
mano_camaro
IYAOYAS
mano_camaro's Avatar
Drives: 22 1LE 2SS M6 Riverside Blue
As an alternative, you could put performance all season tires on your 1 LE from a nearby discount tire since they do touchless mounting. That's what i did and is peace of mind driving in cold temps without thinking about it.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold
2018 black Camaro 2SS M6 Redline Edition/Traded
2016 summit white Camaro RS V6 M6/Traded
mano_camaro is offline   Reply With Quote
Old 12-19-2022, 12:36 PM   #13
WhiteMale
Its the driving part, flexing, that is the real concern though sitting in the cold is of concern, too.
Old 12-19-2022, 12:58 PM   #14
3.8TransAM
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula
Manual says, not recommended to drive under 40F, says do not drive under 20F. 200 treadwear are soft, they freeze, they crack. Argue away, but swap tires and save the stockers for summer.
3.8TransAM is offline   Reply With Quote
