12-15-2022, 08:36 AM | #1 |
open the fuse box in the rear trunk t
Hello,
How to open the fuse box in the rear trunk to remove verdigris? Thanks.
2018 Camaro 2.0 LT Turbo, Conversion to ethanol E85, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights |
12-15-2022, 08:50 AM | #2 |
Personally I’d replace it.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
12-15-2022, 09:09 AM | #3 | |
I would order a replacement while you try to fix this one.
That is a lot of corrosion, not counting what you can't see. To open the old one, I would first shine a light in those 9 rectangular slots around the bottom to see if there are holding tabs in there. Maybe you can pry those and get it open. EDIT: Here are some links which may help: https://www.tbssowners.com/threads/n...e-help.107034/ Last edited by ctrlz; 12-15-2022 at 09:33 AM. |
12-15-2022, 11:51 AM | #4 |
Drives: '16 2SS M6 Join Date: Aug 2019
Wow that is a lot of corrosion. Pretty sure you are going to need to replace it and the wiring harness.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
12-15-2022, 06:53 PM | #5 |
I ordered one!
12-16-2022, 09:16 AM | #6 |
12-16-2022, 12:15 PM | #7 |
Drives: 2018 ZLE Join Date: Feb 2018
Do you have a water leak in the trunk? Park it outside?
12-16-2022, 01:30 PM | #8 |
12-16-2022, 04:29 PM | #9 |
12-16-2022, 04:37 PM | #10 |
That's long term corrosion, so unless that is something he has been doing for a couple of years, he has another problem.
David
12-16-2022, 05:17 PM | #11 | |
Drives: 2017 1SS 6spd Join Date: Jan 2011
If so, +1 on that too! I'm still a little concerned about whether the car has a collision in its past that has compromised the integrity of the interior. I noticed the entire front end and rear diffuser has been replaced... did you instigate that change or was it already done when you bought the car? |
12-17-2022, 03:03 PM | #12 | |
Yeah, I'm a rebel and damn proud of it, sweet home Alabama.
Only Gary Rossington of the original band remains. Quote:
The circuit board burned and it was so hot that the bottom of the box suffered the consequences. Sorry if I don't answer right away, I don't receive an email notification
12-19-2022, 08:19 AM | #13 |
Drives: '23 2SS Rapid Blue Join Date: Apr 2022
Cant tell if thats sand in the box too?
This isn't a FLOOD vehicle? |
12-19-2022, 10:11 AM | #14 | |
it should be waterproof. Apparently not and I'm not the only one with water in the trunk. You think the Bose amplifier needs to be replaced, there has been condensation in the module, which has created oxidation.
2018 Camaro 2.0 LT Turbo, Conversion to ethanol E85, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights Last edited by lynyrd; 12-19-2022 at 10:21 AM. |
