Dyno Show Queen LOL
Can someone educate me on switching from mag ride to coil overs
I'd like to know pros and cons of adding the dssv coil over vs mag ride that I currently have on my ss or zl1 not really about ride cons or pros but about the electronic part of making the switch and if it will mess up anything and what's needed.
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
I have a pretty good write up on my journal about the handling differences. Install is pretty easy.
Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
![]() Drives: 14 Camaro SS 1LE Join Date: Feb 2019
You just have to add xineering shock sims into the mag ride harness, and then you can install any coilover/shock you choose.
The only downside is you do not have an electronically adjustable suspension. Aftermarket coilovers can outperform mag ride, mag ride is just nice because it has a wide range of usage from its adjustability. |
Dyno Show Queen LOL
I have these to put on..
What's all needed is it just bolt on then pluging some kind of thing into the sensors. Could I get a link please to the write up.
![]() Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
Xineering OBD Shock Sim great option... Or just purchase a wrecked ZLE Shock Module... as they don't look for the sensors.
Other than that, install and enjoy! I also have a complete set of like new DSSV's F&R including springs if someone is interested. Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
#6 | |
Dyno Show Queen LOL
#7 | |
Pic of a unit below… still looking for a location shot. Best regards, Dave
#8 |
Dyno Show Queen LOL
Awesome please send location pick when you can. So that is all I need if was to install the oem zl1 1le coil overs on my 17 zl1?
#9 |
Yep! That’s what I did when I first converted my ‘20 ZL1 to the ZLE DSSV suspension!
If you lift up trunk panel, you can’t miss it on left rear. Best regards, Dave
#10 |
![]() Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
Does the transmission need to match for this to work? I found an '18 ZLE module on ebay that I purchased, but I have an auto.
