Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 09-28-2022, 11:57 PM   #1
PFYC
PFYC's Avatar
Drives: Yes
Baffled Oil Catch Can for 2016-2019 Gen6 Camaro SS 6.2L
https://www.pfyc.com/CO3010.html?Category_Code=
Product Description
The 2016 2017 2018 Camaro SS 6.2 liter LT1 does not enjoy oil in its intake. Mishimoto's Camaro SS baffled oil catch can is designed to protect the LT1's intake from becoming an oil slick. This catch can mounts in-line with the PCV system to separate oil and air using a 50 micron bronze filter. The Camaro catch can is mounted away from most intake and supercharger kits to help leave room for future modifications.
This new GM LT1 engine features direct fuel injection, which is great for creating an efficient burn, but allows for carbon build up on the intake valves. Engines with conventional port injection have fuel injected into the intake runners, which helps to wash carbon deposits off the valves. This isn't the case with the Camaro's LT1, making the addition of a catch can vital in preventing increased carbon buildup.
Mishimoto's 2016 2017 2018 Camaro catch can kit features Mishimoto's 2-port Compact Baffled Oil Catch Can which features a bronze filter and internal baffle to better separate the oil from the crankcase vapors. Two direct-fit silicone hoses and an application-specific bracket make for a quick and simple installation. To back up Mishimoto's superior craftsmanship, each Camaro oil catch can kit comes with the renowned Mishimoto Lifetime Warranty!
Direct fit for the 2016 Chevrolet Camaro SS
Single can mounts in line with the PCV system to separate oil from air using a 50 micron bronze filter
Installs in under 30 minutes
Robust, application-specific bracket mounts the can in a serviceable location away from most intake and supercharger kits
Works in conjunction with the stock air /oil separator to deliver maximum protection for your engine
Catch can has a 2 oz. capacity for longer servicing intervals
Silicone hoses include pre-attached stock-style, quick-disconnect fittings for a true plug-and-play install
Billet 6061 aluminum sealed can
Defends intake system and essential components from oil blow-by
Helps maintain proper octane levels to reduce potential detonation
Filter and can are fully serviceable
Internal air diverter turbulates air longer to improve oil separation
PFYC is offline   Reply With Quote
