08-16-2022, 12:35 PM | #1 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
Coil over suggestions?
Thinking I want to take the next step as I look to do more road courses down the road. The car gets caged this coming winter.
Current suspension mods: BMR front & rear sway bars Koni yellow shocks & struts BMR trailing arms BMR toe links Z/28 springs BMR sub frame connectors and drive shaft tunnel brace BMR drive shaft safety loop BMR rear cradle bushings R1 Concepts slotted & cross drilled rotors Goodrich braided brake lines DOT4 fluid Forgeline GA3 forged aluminum wheels (20”x9.5” & 20”x11”) What would your suggestions be and why? Thanks. |
08-17-2022, 06:57 AM | #2 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
I have the Entry level BCracing coilovers from phastek, and I love them. I installed them right out of the box, and haven't looked back since. Very stiff at max adjustment and nice n soft in the lower settings. For $1100 shipped, you can't go wrong. I have had 0 issues with mine to date. They are also a reputable company, and stand behind their product.
Now that I re-read your original question... I can't speak for the durability as far as road course racing goes. I only drive mine on the street, and for that they have been quite reliable.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
08-17-2022, 08:47 AM | #3 |
Thank you for sharing.
Yes I want something that is fully adjustable and shines in a competitive environment. |
08-17-2022, 09:23 AM | #4 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
I love my Pedders
08-17-2022, 10:37 AM | #5 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
afe/pfadt Featherlight's
08-17-2022, 12:48 PM | #6 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
For the competitive side Pfadt/AFE, Olins, or KWs. The only downside to going with "racing" coil overs is that they will at some point need rebuilding which is not cheap, requires sending them back to the manufacturer. I had Pfadts version 1 on mine for a few years, and when they started leaking found out AFE wasn't supporting the original Pfadt version. I decided no more tracking so I went with KW V1s for street use. They do make V3s and Club version more suited for track. Olins are nice but they have an high rebuild cycle depending on how you use them. It's spelled out on their webisite and if I recall just street use they recommended 18K miles for a rebuild. Pedders and some of the cheap ones don't last on the track. My very first coilover was Pedders and they lasted one season tracking before all 4 leaked.
08-17-2022, 01:05 PM | #7 |
Thank you!!!!
I’ll have to check out KW. |
08-17-2022, 04:12 PM | #8 |
if your gonna go with something besides pfadt's go with a model that has an external reservoir and offer titanium nitride coating as an option, ti Ni greatly reduces wear on seals.
The new pfadt Featherlight's are gonna be hard to beat plus your not going to have to change your control arms and install adapter plates that fit standard coilover mounts. |
08-17-2022, 10:44 PM | #9 | |
08-18-2022, 06:29 AM | #10 |
How do you like your Koni Yellows? I lloking for a set Bilstiens but they are hard to get and wonder if they are as good as the Koni's?
Orange Krush II
08-19-2022, 06:45 AM | #11 |
Love the yellows. I got them on here from one of the vendors that was having a sale. Paid like $20 more than the oranges.
08-21-2022, 08:01 AM | #12 |
Drives: 2012 Camaro SS Join Date: Dec 2019
I have the pedders extreme coil overs and love them. Rides great and I am able to hook much better from a launch.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
09-05-2022, 06:24 PM | #13 |
400HP used to be enough..
Drives: 2010 2SS rs manual Join Date: Aug 2009
I have KW Variant 3 and they are not good. I have the fronts adjusted one click from full stiff to keep the strut from bottoming out. The rears are leaking after only 5K miles. Spend your money elsewhere.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
10-11-2022, 10:41 PM | #14 | |
Drives: 2001 Camaro Join Date: Jan 2018
