08-13-2022, 10:36 AM | #1 |
Drives: 2017 Camaro SS 1LE Join Date: Sep 2021
Blurry HUD After Car Detailing
Hey guys, I picked up my car from getting fully detailed went to the track last night and when I turned on the heads up display it was blurry as hell. Seems like the guy that detailed my car sprayed the HUD with some sort of dashboard conditioner and the image looks terrible. Does anyone know what to use to clear it up? Thanks!
08-13-2022, 11:47 AM | #2 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Take it back to the detailer and tell them to resolve the issue and to next time be a bit more careful. You paid them to detail your car, I'd make them resolve the issue. (Just Me)
08-13-2022, 11:52 AM | #3 |
^^^ What he said
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
08-13-2022, 12:12 PM | #4 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
From my owner's manual...Good luck.
Care of the HUD Clean the inside of the windshield as needed to remove any dirt or film that could reduce the sharpness or clarity of the HUD image. To clean the HUD lens, use a soft, clean cloth that has household glass cleaner sprayed on it. Wipe the HUD lens gently, then dry it. Do not spray cleaner directly on the lens because the cleaner could leak into the unit |
08-13-2022, 01:59 PM | #5 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
As others have said, go back, explain the situation and I'm sure they can fix it. More that likely some product got on the HUD screen and smeared it.
08-13-2022, 02:13 PM | #6 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
08-13-2022, 02:20 PM | #7 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I would just clean it myself, you're going to drive your car back to the detailer and waste your time so they can wipe the screen clean for you? If it didn't damage anything then there is nothing to worry about.
08-13-2022, 02:37 PM | #8 |
Yep, it's a matter of principle to me, and not only that, if you F something up (for whatever reason) fixing something the detailer messed up, it's on you. If you take it back to them and they F something up, it's on them. Again... Just me... Besides... It's just another excuse to take a drive in the Carmaro. Any drive in the Camaro is not a waste of my time, even if it's back to the detailers.
08-13-2022, 02:46 PM | #9 | |
08-13-2022, 06:45 PM | #10 | |
08-13-2022, 06:48 PM | #11 | |
08-13-2022, 07:01 PM | #12 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Chances are they have interior detail product on the plastic cover on the HUD. Use a glass cleaner (without ammonia) dampen a waffle weave and clean the HUD cover on the dash. I clean mine every time I do an interior clean.
08-13-2022, 07:05 PM | #13 |
Good point. HUD should be properly cleaned regularly anyhow. You don't need to wait until it gets messed up by a detailer's product.
08-13-2022, 08:05 PM | #14 |
Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
This would make me find another detailer...if they turned it off, they had to have gone looking for the settings to do it as it's not just an on/off switch. That means they were either covering up what they knew was a screw up, or they were snooping through your menus for some other reason. Even if it's out of boredom, there's no good reason for that.
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
Tags |
1le, blurry hud, heads up display, hud |
