07-22-2022, 03:45 PM | #1 |
Drives: 2022 VOM 2SS 1LE M6 Camaro Join Date: Nov 2021
Rear bumper fitment up near lights
Ive been meaning to post this for a while, but I kept forgetting. I finally got some good photos.
I cant be the only one with this fitment issue - this is how the car has been since the day I bought it. They are almost always in this place, pushed out a bit - especially on the driver side. Anyone mess with this and figure out the cause/solution? *EDIT*: The answer has been found: it's for heat expansion, and with me being in Vegas at 110+ degrees right now, it's ESPECIALLY noticeable.
2022 Vivid Orange 2SS 1LE ordered (BDQDHT, 1G1FG1R7XN0108251) - ETA 20220223
20211120 - 1100 --- 20211207 - 2500 20211208 - 3000 (TPW: was 20220103, now 20220124) 20211220 - 3400 (TPW: 20220110) 20220114 - 3800 --- 20220122 - 4300 (1LE Wrap Shuffle) 20220125 - 4B00 --- 20220129 - 4200 (Shipped! ETA: 20220223) 20220212 - 4800 --- 20220216 - 6000! 2024 Silverado EV RST First Edition on reserve, as well. Last edited by MightyBobo; 07-22-2022 at 05:01 PM. |
07-22-2022, 03:55 PM | #2 |
I’d say we’ve all questioned this area of the cars either on here or to other Camaro owners. Here’s an older thread on this topic.
https://www.camaro6.com/forums/showthread.php?t=578373
07-22-2022, 03:58 PM | #3 | |
Furthermore, this makes a LOT more sense for me: I live in Las Vegas, and my gap is quite big on hot days (which are 110+ here). I'll see how it looks come "winter".
20211120 - 1100 --- 20211207 - 2500 20211208 - 3000 (TPW: was 20220103, now 20220124) 20211220 - 3400 (TPW: 20220110) 20220114 - 3800 --- 20220122 - 4300 (1LE Wrap Shuffle) 20220125 - 4B00 --- 20220129 - 4200 (Shipped! ETA: 20220223) 20220212 - 4800 --- 20220216 - 6000! 2024 Silverado EV RST First Edition on reserve, as well. |
07-22-2022, 04:04 PM | #4 |
2020 Shadow Gray 2SS
My 2020 2SS looks the same as your pictures... Bugs me...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
07-22-2022, 04:52 PM | #5 |
yup pretty normal but it sucks
07-22-2022, 08:02 PM | #6 |
The ziptie fix worked just fine for me, they've been on the car for years and the bumper always looks decent now.
#we_love_ghetto_fixes
07-23-2022, 10:43 AM | #7 | |
I'm curious how said zip ties would work in Vegas temps and dryness.
07-23-2022, 11:19 AM | #8 | |
Thank you Al Oppenheiser!
How not to mess up the tail lights with the zipties here: https://www.camaro6.com/forums/showp...ostcount=12132 |
07-23-2022, 11:27 AM | #9 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
EDIT: I just noticed the original post involves a 2022. On the 2019+, you have to remove the rear bumper cover to remove the taillights. So there doesn't appear to be a way to apply this zip-tie fix to a 19+ since you can't just pop the taillights out to access the bumper tabs like we can on the '16-18's... or as I can on my "de-freshed" 2021.
Funny timing for this topic to come up - I was just going to post some advice on that other zip-tie thread. Be careful how you orient the heads of the zip ties. The first set of zip ties I installed caused some interference with the taillights - nothing readily visible, but just enough that the trunk would not latch without some extra downward force being applied. See the "no" photo below (which I took before trimming the tails off the zip ties). The other photos show my second round of zip ties. This time I oriented the heads of the ties downwards so they would not create interference with where the taillights slide into the brackets - after this change, the trunk lid latches normally again by just letting it fall down. Note that although my car is a '21, it has the taillights, taillight brackets, and rear bumper cover for a '16-18. So potentially this is a unique issue. It still seemed worth mentioning in case it helps someone else applying the zip-tie fix from ending up with the same "trunk won't latch under its own momentum" issue... Last edited by The Maverick; 09-06-2022 at 11:21 AM. |
09-05-2022, 03:21 PM | #10 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Im going to look at this solution but wanted to add that my built in Jul 23 model has this
09-06-2022, 09:56 AM | #11 |
I’m pretty sure you have to yank the entire bumper on the 2019+ cars, as opposed to just being able to remove the taillights on the 2016-2018 cars. So, the tie wrap solution is a no go for me…
Oops..just saw Maverick said the same thing. |
09-06-2022, 11:24 AM | #12 |
09-06-2022, 11:27 AM | #13 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
It's "normal" I live with it, only does it on the right side, hot temps and direct sun. I don't pay attention to it anymore.
05-25-2023, 06:22 PM | #14 | |
Drives: 2022 Zl1 Camaro Join Date: Jul 2022
I'm in Vegas too. Brought mine to Finley Chevrolet. Gave me a rental for two days. They'll bring it to a body shop and fix it for free. They're aware of the issue and didn't fight me at all about it. My driver's side was the worst. Looks just about perfect now |
