07-19-2022, 01:06 PM | #1 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2019
95 degree track day tomorrow. Any advice?
Doing my first full track day tomorrow. Ive done a good amount of autox and some time trials, but this is my first track day. Its going to be hot as the devil. Any advice for running in the extreme heat?
07-19-2022, 01:11 PM | #2 |
Who Needs to KNOW?
Hydrate the DAY BEFORE. Continue hydrating the day of. Keep AC on, seat cooling if so equipped.
If temps start creeping up - pull off, spray down front heat exchangers ( radiators ) and go back out if time allows. Take extra water for said sprayer ( lawn-garden section). Take extra t-shirt for the ride home - feels good to put on DRY clothing at end of HOT track day. Shower.. if available. IF you feel yourself feeling dizzy or having hard time focusing, come in, park in shade if available or AC room.
ing for grip.
07-19-2022, 01:13 PM | #3 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
Truly the most important thing is to stay hydrated and know ur bodies limit.
07-19-2022, 01:31 PM | #4 |
ok #1 hydration. thanks. Ill get a sprayer once im off work today too
07-19-2022, 01:33 PM | #5 |
Shadow Gray '19 ZLE M6
Agree with above. There is no shame in cutting your session short if you're not feeling 100%.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
07-19-2022, 01:54 PM | #6 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
Tires will grease early, don’t push too hard. Focus On your line and situational awareness. Drink lots of Gatorade like others said.
Have fun and don’t worry about Lap Times. No records are set on hot days. |
07-19-2022, 01:57 PM | #7 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Well we are having 102-105 degree track days down here and I will mention the following:
Keep careful watch of the air pressure in your tires. I am running AZENIS RT660 for example and I run around 26 PSI cold and with track temps I can see around as much as 36-38PSI Hot. I usually take some air out of the tires to keep pressures down. It is also a good idea to check the torque on your lugnuts at least ONCE during the track day (140 ft lbs). If you feel your brakes are FADING because of the heat, DO NOT continue on to try and deal with that situation. It is best to simply cut your sessions shorter. Your first few track sessions in the morning and afternoon will typically be faster than those later in the day. In a typical 30 minute session for example, I may run the first 20 minutes of it. Keep a careful watch on water temps and engine oil levels. As others have indicated HYDRATION is the key. Energy drinks, soda, and anything with sugar or caffeine in it ARE NOT good hydrators.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
07-19-2022, 02:54 PM | #8 |
Im running the SC3s so I will probably start pretty low around 27.
A wheel flying off into the sunset has always been my biggest fear so I'm way ahead of you on the lugs! I just put in new DOT 4 fluid. RBF 600. Kind of wish I had the 660 for tomorrow. I will definitely not push on weary brakes. Temps will definitely be a focus Thanks! |
07-19-2022, 03:44 PM | #9 | |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
07-19-2022, 08:09 PM | #10 | |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
07-19-2022, 09:31 PM | #11 |
07-19-2022, 09:32 PM | #12 |
07-20-2022, 12:36 AM | #13 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
07-20-2022, 06:36 AM | #14 |
I dont torque my wheels during the session but I generally just check them at 20% less just to ensure nothing as backed off.
Orange Krush II
