07-13-2022, 02:09 PM | #1 |
Drives: ‘21 ZL1, ‘17 F-150, Join Date: Jul 2022
Is it totaled?
Can’t make this up. Bought this car Monday at 5:30, 2019 manual 2ss, 6 hours later a deer runs right out in front of me. Is it totaled? No airbags deployed, seat tensioners locked up though.
07-13-2022, 02:14 PM | #2 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
I don’t think they will total that in todays environment
07-13-2022, 02:15 PM | #3 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
I would have gone back and slit the deer's throat. Its the only way to be sure.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
07-13-2022, 02:16 PM | #4 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Oh... man, that is a huge bummer... Sorry to see that. No, I don't think it's totaled. Repair cost will need to be over the value of the car. I doubt that's the case.
07-13-2022, 02:48 PM | #5 |
Drives: 2002ss Join Date: Aug 2008
07-13-2022, 03:16 PM | #6 |
Bummer! Six hours of ownership- so sad.
Unless there is a lot of hidden damage which is not likely with a deer strike - the repair costs should below market value enough to deem the car repairable. Good luck.
07-13-2022, 03:16 PM | #7 |
Who Needs to KNOW?
I sure hope headlights on yours is not same as mine... 6+wk backorder!!
ing for grip.
07-13-2022, 03:18 PM | #8 |
The alignment felt perfectly fine, however I hit a bump driving the car to the body shop and it felt so bad. Could there be frame damage?
07-13-2022, 03:34 PM | #9 |
It's unlikely to be totaled, and from these pics I don't think there is frame damage either, impact absorption in the front is supremely done (don't ask me how I know ). The weirdness you felt when hitting a bump could be from a displaced part.
Give her to a good body shop and they should take care of this. Wait times may be excessive, unfortunately
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 07-13-2022 at 05:26 PM. |
07-13-2022, 03:36 PM | #10 |
Hard to say if it’s a total of not. Wait for the insurance adjuster to check it out before thinking it might total. Just depends on the damage and the cost to repair it. Good luck!
07-13-2022, 04:43 PM | #11 |
Drives: 2017 Focus RS Join Date: Dec 2021
I used to work in auto collision field no that won’t be totaled it looks mainly cosmetic. It depends on your insurance provider but typically unless the cost to repair is over 50% of the value of the vehicle they won’t total it(the percentage varies by provider).
2023 ZL1, M6, Shadow Gray
07-13-2022, 05:02 PM | #12 |
Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
Wow, that sucks...glad you're OK.
Based on my experience with a GTI a couple of years ago - make sure the adjuster gives a FULL estimate before repair work starts. The idiot that did mine took a cursory look and told the shop to start working on it. The more they tore it down to fix it, the more stuff they found - over and over and over. By the time the cost of repair came up to where they should have totaled it, they had already spent too much to back out of it, and flat out refused to total it. Insurance company spent a ton, shop made a ton, and I'm the one that got screwed...
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
07-13-2022, 05:32 PM | #13 |
Drives: like an old lady Join Date: Jun 2012
whew that was close.
i thought you found out it had 5w30 non dexos oil in it. would've definitely been totaled then.
07-13-2022, 05:54 PM | #14 |
see the pics in the 5th gen forum of mine...pushed sideways by a semi at 60 mph.$9400 in damage and counting but they are going to fix it.what you have there should buff right out...thread is titled bad day on the road,page 2.
