06-26-2022, 09:48 AM | #1 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Dont Let this Happen to YOU
Ok track day yesterday at Motorsports Ranch Cresson Texas on the 1.7 CCW. Temperatures are 100+ degrees and turnout was relatively LIGHT because of it. Anyway there were ten of us in the ADVANCED group and I was booking it pretty good for the conditions in the second session and I got the dreaded REDUCED POWER MODE
So my first reaction is WTF??? This EXACT issue is why I am NA and not running a supercharged engine like I had in my ZL1 1LE. Anyhow, I quickly checked the water temp and that was just slightly above normal so that was OK. The car at MOST runs only about 10 degrees normal when NOT racing it and that was where I was at. So I pull the car into the pits and I take it over to GSPEED which is a race shop at MSR and they try to clear the codes with NO SUCCESS. So upon further investigation we found that apparently what happened is my DAMN AC belt broke and in the process wrapped itself around harness that is attached to the timing cover and literally tore the wires out of the VVT and CAM Position sensors. I guess it also affected the oil pressure sensor as well. So with the car in REDUCED POWER mode I was able to drive the car home after I determined that AAA was going to NOT come out to TOW me after saying they would (this has happened THREE other times, HORRIBLE service). A word here about reduced power mode. The best thing to do is to manually shift the car keeping the RPMs between 2000-2500 RPM. The track is about 47 miles away and MOST of the time I was in M7 at about 60MPH. Car was happy here. On a side note, why the hell GM would have a harness close enough to the AC belt that breakage MIGHT entangle the harness is beyond me. Afterwards I went on-line and found that this type of thing while uncommon is not unheard of. I guess it also depends on how fast the belt is spinning when it breaks (LOL). The MORALE of this little story is to occasionally change the belts out on your car even if they look like they DONT need it. From now on, I am changing these things out at least once a year.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
06-26-2022, 12:07 PM | #2 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
How many miles were on that belt?
06-26-2022, 12:13 PM | #3 |
06-26-2022, 06:57 PM | #4 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Thanks for the warning, I'm still on the original belt. I have a new one sitting around already but read that it is a pain to install because it is stretch to fit.
06-26-2022, 07:42 PM | #5 |
Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
Hello guys, is this belt for all Camaro trims, or just the LT1?
EDIT: I meant to ask, is the belt setup the same for all Camaro trims. Geoff |
06-27-2022, 04:09 PM | #6 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
You have AAA and they refused service, I would think that would be and issue.
06-27-2022, 04:12 PM | #7 | |
Of course they will use the standard excuse that the pandemic has caused all these service issues which is BS. The truth is they just cant manage it properly.
06-27-2022, 04:14 PM | #8 |
i replaced mine a few years ago when my tensioner went bad dealer said they wouldnt cover it so i had to pay for it so 35k and belts have already both been changed thank god lol
06-27-2022, 04:41 PM | #9 |
Back in the late 90's AAA sent me a letter saying they would no longer tow me from the Baytown Raceway. This was after the second time I scattered the 10 bolt in my '72 Chevelle. The trick from then on was to get the car outside the front gate, tell the dispatcher I what road I was on, and not ever mention the words "raceway" or "drag track".
2021 LT1, A10, RotoFab CAI, Flowmaster American Thunder axle back exhaust, JLT catch can, Katzkin leather interior.
06-27-2022, 04:56 PM | #10 | |
lol my buddy totalled his old car at autoclub speedway in cali and they came all the way into the paddock put it on a flatbed and towed it back to his home and left is in his driveway who knows anymore its weird
06-27-2022, 07:16 PM | #11 | |
Drives: 2019 Chevrolet Camaro SS Join Date: Apr 2021
06-27-2022, 08:20 PM | #12 |
Drives: 2018 Camaro ZL1 Join Date: Nov 2009
I think the ZL1s automatically turn off the AC during WOT am I right?
2018 ZL1 M6 NGM
PPF and Ceramic coating IG: NGMZL1 2010 2SS RS --- SOLD MODS- Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs |
06-27-2022, 09:23 PM | #13 |
Yeah it disables the compressor clutch so that it disengages at some RPM point or it may be controlled with input from the throttle position sensor so that when car sees full throttle it disengages the AC clutch but of course that dont stop that belt from spinning on its pulley LOL
06-27-2022, 09:25 PM | #14 | |
Well we were getting LOW VOLTAGE codes on the CAM position sensor and VVT sensor mainly because the damn wires were ripped out of the sensors they were connected to. I didnt see the code numbers myself.
