06-06-2022, 09:59 PM | #1 |
Drives: 2008 z06 Join Date: Feb 2018
New to me ZL1 build
Just bought a 2013 Zl1 M6 black on black 19990 miles looking to dive into starting the build I want to max out stock pump on e85 with a BAP and max out the clutch all I do is roll racing. Was thinking of this
Headers or catless down pipes Some kind of CAI that works with stock TB Injectors BAP DSX flex fuel sensor Catch can Hoping this gets me over 600whp if not I’ll do a 10 or 18% lower reinforced brick ice tank and Heat exchanger |
06-07-2022, 05:16 AM | #2 |
Drives: 2013 zl1 vert Join Date: Dec 2018
congratulations on the zl1. i have a 90mm throttle body and 5" jlt intake i can give you a deal on. it will get you going in the right direction.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
06-07-2022, 09:41 AM | #3 |
06-07-2022, 09:46 AM | #4 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Talk to Ted at https://jannettyracing.com/
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
