05-18-2022, 05:31 PM | #1 |
Drives: 2019 camaro 2ss Join Date: Feb 2020
Vibration in steering wheel above 40mph
Few nights ago I hit a pot hole of some sort, now whenever I’m on the gas above 40mph the car starts to shake/vibrate, and I feel it in the steering wheel. The thing throwing me off is that the vibration/shaking will go away even at 60 mph if I completely let off the gas and let it cruise. And then with the slightest touch of gas, it begins shaking again. What would be your guys’ first thoughts?
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
05-18-2022, 10:35 PM | #2 |
Monterey County Camaros
If it feels like rumble strips it's the transmission shudder. Do the trans fluid flush ASAP
Follow us on Instagram @montereycountycamaros
05-18-2022, 10:51 PM | #3 |
Didn't the 2019 SS have the A10 (10L80) already? That transmission isn't supposed to shudder.
05-19-2022, 12:35 AM | #4 |
Yeah I have the A10
05-19-2022, 01:00 AM | #5 |
Drives: 2022 2 SS 1LE on order ....now a 23 Join Date: Jan 2022
Wheel out of balanced or bent?
05-19-2022, 03:48 AM | #6 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Yeah, I would get the wheels checked as a starting point. Something may be bent or out of balance.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
05-19-2022, 05:27 AM | #7 | |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
05-19-2022, 10:25 AM | #8 |
Don't you think the fact that it only starts doing it with the slightest bit of gas above 40mph would point to something else? I figured if it was the wheel\tire itself it would just be constant
05-19-2022, 10:30 AM | #9 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
That usually is indicative of the Transmission shudder. And 2019's were listed as having it, but granted that was supposed to be exclusive to the A8 and not the A10. Was there a different A10 trans for 2020+? or was it the 10L80? The trans shudder is known to happen between 30-80mph, and at the usual same places, for me it was 50mph, and 70mph on my 2016. As soon as I applied more than a light accelerator pedal, the vibration would stop. To my knowledge and I could be wrong, if it was a wheel imbalance, or tire imbalance you would feel it while braking as well, not just accelerating. And if it was an alignment issue you would notice the car pulling to one side over the other when you take your hand off the wheel (excluding road crowns / Tire pressure issues) The only other thing I can think of that may be causing that is a warped rotor but again that's usually felt while braking, not sure if it can be felt while acclerating.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
05-19-2022, 10:32 AM | #10 |
Drives: 2022 VOM 2SS 1LE M6 Camaro Join Date: Nov 2021
I'd be starting by investigating the wheels, regardless of what people think about adding throttle or not. You hit a pothole and it started right after that. Any mechanic worth his salt would begin with the wheels/tires, and work his way to the suspension.
2022 Vivid Orange 2SS 1LE ordered (BDQDHT, 1G1FG1R7XN0108251) - ETA 20220223
20211120 - 1100 --- 20211207 - 2500 20211208 - 3000 (TPW: was 20220103, now 20220124) 20211220 - 3400 (TPW: 20220110) 20220114 - 3800 --- 20220122 - 4300 (1LE Wrap Shuffle) 20220125 - 4B00 --- 20220129 - 4200 (Shipped! ETA: 20220223) 20220212 - 4800 --- 20220216 - 6000! 2024 Silverado EV RST First Edition on reserve, as well. |
05-19-2022, 10:35 AM | #11 | |
I agree in checking tire/wheel first. And inspection may not show damage. You could have knocked off a wheel weight and only a spin balance will show that problem. |
05-19-2022, 10:54 AM | #12 | |
As I mentioned before, if it was a wheel imbalance or tire imbalance you would feel that while braking, and not just while accelerating. It would also look like an alignment issue as the car will pull to one side or the other. And you would feel that pull in the steering wheel as well.
05-19-2022, 11:07 AM | #13 | |
Drives: 2021 2SS Join Date: Jul 2020
05-19-2022, 11:12 AM | #14 |
as someone mentioned earlier, the feeling is almost identical to driving over rumble strips. its a very strong vibration\shake. could it be a control arm causing this? or would the fact that there needs to be a bit of throttle to activate it rule this out?
